RV.Net Open Roads Forum: Class A Motorhomes: tire size question
 > tire size question
Goldencrazy
madison wi
Posted: 02/14/12 03:43pm Link  |  Print  |  Notify Moderator
I currenty have 19.5 inch tires on my 2012 winnebago vista 30T. I notice the 32 ft models in both Vista and sightseer have the 22.5 inch tires. My 19.5 seem small and I think the chassis on the other are the same as mine. Could I put the larger tire on mine or were there be many other things to change? What difference would larger tires make. I already have the Kelderman so my ride is fantastic and the roadmaster reflex and tiger trac bar provide great stabiity and tracking. Can I do it and is there an advantage?
bsinmich
Holland, MI
Posted: 02/14/12 04:05pm Link  |  Print  |  Notify Moderator
Axle ratios, transmission gearing, wheel clearance in the wheel wells and everything else near the wheels would have to be changed. There just is not enough room for those on your MH. You may also need a ladder to get up into the MH. You are much better off with what you have. I wish I didn't have the 6 steps up to mine. We both have problems with steps.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Ames
South Central Florida
Posted: 02/14/12 04:14pm Link  |  Print  |  Notify Moderator
I agree with bsinmich
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 2012 Dodge Durango RT AWD Hemi
rgatijnet1
Posted: 02/14/12 04:29pm Link  |  Print  |  Notify Moderator
Since you say that the ride is fantastic with your 19.5 tires, why would you want to go to a more expensive tire? There are many things that would be affected but probably the most expensive may be the new axles and brakes, to match the larger wheel bolt pattern.
Goldencrazy
madison wi
Posted: 02/14/12 04:45pm Link  |  Print  |  Notify Moderator
I wondered. We changed my tires/wheels on the Smart Car from 15 to 16 inch and the ride improved in terms of stability and we made no other changes. Of course the bolt pattern was the same and we had enough room in the wheel wells to do it. At any rate I don't need to do it but curious.
Fiesta
Sherman, TX
Posted: 02/14/12 05:04pm Link  |  Print  |  Notify Moderator
19.5" tires and wheels are cheaper than 22's.
I and most people can change a 19.5 but not a 22.
Would a 22" ride and handle better?
Would there be enough fender clearance?
22"'s are heavier so you could up with reduced MPG.
Correct Inflation pressure is more important than size.
Why change??
ArchHoagland
Clovis, CA, USA
Posted: 02/14/12 11:55pm Link  |  Print  |  Notify Moderator
Tires would be, ballpark $3,000. Wheels would be, ballpark $2,000.
I don't know if you would get $5,000 worth of improvement.
I'd put that 5 grand in the fuel tank and see the USA
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
Scott & Jill
Posted: 02/15/12 10:14am Link  |  Print  |  Notify Moderator
I think when you change the tire size that also affects the speedometer?
Life is too short; enjoy it the best way possible
eadeal55
Suffolk VA
Posted: 02/15/12 11:14am Link  |  Print  |  Notify Moderator
the main reason why you have 19.5in tires on your 30T and the 32K,35F and 36D ft models have 22.5in tires is the chassis GVWR. The 30T only has a 18,000lb chassis, where the 32K has a 20,500lb chassis. You could probably put 22.5in tires on your 30T, since the actual MH body probably has the same dimensions in the wheel wells, but not too sure what the real benefit that would be.
I've been riding on 19.5in tires for 7 years and 25K miles now, and for my 20,500lb chassis, its been a good smooth ride. I look forward to trading up to a 36ft MH in the next year or so with a 22 or 24K lb chassis, and 22.5in tires...
Andy & Lee, plus Ruby & Bella, the Cocker Spaniel girls
'05 Fleetwood Bounder 33R, F53 w/6.8L V10...towing a
'07 Chevy HHR LT2 w/2.4L EcoTec,
Blue Ox Aventa LX, Brake Buddy Classic
FMCA #F359977 - Colonial Virginians
FCRV #733452 - Tidewater Wheels
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 02/15/12 12:04pm Link  |  Print  |  Notify Moderator
Bob, you can take your coach to a knowledgeable tire shop and they can give you the spec's that you need (clearance etc.) and the cost for free. I've owned both and prefer 22's due to you have more tire on the road surface and you ride a little higher. IMHO if you can afford it go with the 22's! It will change your speedometer, but if you decide to go with 22's look at what speed your driving with the 19's and what RPM's your at! The speed will change, but the RPM's will not and you'll learn how to drive with your tach. In my coach I don't care what the speedo is reading. I drive at 1900 RPM's because that's the sweet spot that I get the best milage for my coach.
