RV.Net Open Roads Forum: Class A Motorhomes: Grey Water Soap Buildup
 > Grey Water Soap Buildup
pkunk
Questa, NM
Posted: 02/15/12 04:41pm Link  |  Print  |  Notify Moderator
BigSkyBob wrote:
I'm curious as to how you got the ice cubes into the gray water tank.
That tank had it's own vent to the roof. One by one almost. Actually slowly poured them down from the bag. Wouldn't work on my present coach as it's a shared vent.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
lanerd
Newport, OR
Posted: 02/15/12 04:53pm Link  |  Print  |  Notify Moderator
cdking1 wrote:
Okay, Robin, but I wonder how the soap got on his sensors. This is what the Mfg said. Being an electrician and plumber, I already know there is no magic way for this to happen. Just trying to help. charlie in texas
Charlie, he never said soap got on his sensors. He did say the sensors are on the "outside" of the tank! He also said that the mfg suggested he might have a "soap build up" on the inside of his tank at the 8% level. Read the OPs post again.
To the OP, you might try some of the commercial "soap scum removers" that is used for shower doors and walls. On your trip to Phoenix, put in a bottle of your choice with a few gallons of water and let it slosh around during the trip. Upon arrival, drain the tank and then refill and drain again. Not sure if this will work, but it might be worth the effort/cost.
If this does work, I would then put in the Calgon on the next trip and every trip thereafter.
Good luck
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
PHE
Posted: 02/15/12 06:21pm Link  |  Print  |  Notify Moderator
pkunk wrote:
On my old Allegro I had the same problem with my seelevel system. I put 5 gals vinegar and about the same amount of water, added 3 boxes of baking soda and 2 bags of ice cubes. I then went for about a half hour drive, switching lanes, starting & stopping and generally driving like a drunk. Got home dumped the gray water and filled with fresh and the gauge worked perfectly. Now I always use some TSP in both tanks and that keeps any thing from sticking.
Glad it worked for you BUT.....
Vinegar is neutralized by Baking soda
Suggest you use one or the other but not both
phe
Robin1953
Ashton, WV
Posted: 02/15/12 06:22pm Link  |  Print  |  Notify Moderator
Unless I read it incorrectly the soap buildup was not on the sensors directly but a buildup on the inside of the tank where the sensors are attached on the outside of the tank. While I was thinking about your response about trying to help I remembered that when I was in an RV park in San Leon, TX last year there was an outfit that came to a neighboring RV and cleaned the RV black tank from the outside with high pressure. Not sure if they did the same for grey tanks but they showed pictures on their web site of before and after cleaning and it looked like a new tank. I am going to ping around and see if I can find that website again and post the link if I find it. Not sure if their would be anything like that at the OP location but it might be something to consider.
The guy was a service agent of this company All Pro Waterflow
* This post was edited 02/15/12 06:39pm by Robin1953 *
Robin Brumfield
2011 Dodge 3500 DRW CC
2012 Jayco Eagle SuperLite 31.5RLTS
I am still wayne_tw
everywhere
Posted: 02/15/12 06:32pm Link  |  Print  |  Notify Moderator
cdking1 wrote:
Hi, these cheap little sensors on the tanks are mostly a joke. If they have a coating on them and stay wet they will show a reading. People have used the bags of ice trick, put a few gallons of water, a couple of bags of ice and drive to slosh the ice around, seems to work okay. But they get clogged up again. You can prove this by letting the sensors dry out and you readings will probablay go to low or empty. I finally gave up on them and empty based on estimated use or when you see water backing up in the shower drain, usually the low point of the grey system. A lot of people just leave the grey valve open when parked, I have a masarater so I open and close mine based on need. charlie in texas
You obviously did not carefully read the original post or do not understand what the SeeLevel sensors are (they read from outside the tank and never get wet).
pkunk
Questa, NM
Posted: 02/15/12 07:14pm Link  |  Print  |  Notify Moderator
When you add baking soda to vinegar it foams, and that action cleans the soap scum. The ice cubes (if you can get them in ) help scrub the tank.
phe
Bflag
Arizona
Posted: 02/15/12 09:56pm Link  |  Print  |  Notify Moderator
Using bar soap? I gave that up and only use liquid soap. bar soap will turn back into a solid when it drys as evidenced on shower walls. I haven't had a bit of build up in sinks or shower since switching. Well, except where it spills and dries in a glob.
89 Bounder 30' First MH, first experiment in FT'ing.
rolling_rhoda
South Dakota
Posted: 02/16/12 04:29am Link  |  Print  |  Notify Moderator
How about some simple green concentrate and a few gallons of hot water before driving around?
Aridon
SE Florida
Posted: 02/16/12 04:32am Link  |  Print  |  Notify Moderator
I wouldn't bother but if I did I'd probably use the shower drain.
2008 Newmar 4330 (Modified)
blucrabbie
Wake Forest, NC
Posted: 02/16/12 05:03am Link  |  Print  |  Notify Moderator
pegdiver wrote:
We have the sealevel system. We used Pine-Sol and water in the tanks on the way home. It seems to clean the tank walls without doing anything else. We dump as soon as we stop at home. Easy, cheap, smells good...
x1 on the Seelevel system. We use Pine Power. We pour a little into the tanks with tanks about 1/3 full, travel and let them slosh around. We then dump when we arrive at the campground. Smells good and keeps the tanks clean.
New 2 us
07 Allegro Bus 40QSP
08 Honda CRV EXL with Blue OX and US Gear Braking System
FMCA #381833
Our Camping Adventures
hubby and i empty nesters
n4gnn n4hon
I Never Look Back, I'm Not Going That Way!
