RV.Net Open Roads Forum: Tech Issues: Water heater rinser
 > Water heater rinser
go wild
Minneapolis, MN
Posted: 02/15/12 03:43pm Link  |  Print  |  Notify Moderator
Has anyone every used a water heater rinser? It's supposed to help wash out sediment that collects on the bottom of the tank. I always drain my tank after each trip so I'm thinking that would accomplish the same thing but looking for other opinions...thanks!
Here's one on Amazon:
http://www.amazon.com/Camco-11691-Water-........B002XL2IBS/ref=acc_glance_auto_ai_ps_t_2
2007 Jeep Commander 4X4 HEMI
2010 Jayco 17Z
wolfe10
Posted: 02/15/12 03:47pm Link  |  Print  |  Notify Moderator
I just use a 5' length of cheap clear vinyl hose that fits into the drain hole and start a siphon to "vacuum" the minerals out of the bottom.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
robsouth
Near Atlanta, GA
Posted: 02/15/12 04:03pm Link  |  Print  |  Notify Moderator
X2
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
I am still wayne_tw
everywhere
Posted: 02/15/12 04:35pm Link  |  Print  |  Notify Moderator
I have one and it forces out a surprising amount of "stuff!"
therink
Rochester
Posted: 02/15/12 04:55pm Link  |  Print  |  Notify Moderator
I cut the end off an old small diameter garden hose and regularly flush it out. It is amazing what builds up from hard campground water.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
ksg5000
Oregon
Posted: 02/15/12 05:06pm Link  |  Print  |  Notify Moderator
I purchased/used one last yr for my 92 Jamboree - water quality in Oregon must be great because I had almost nothing at the bottom of that tank.
Kevin
garym114
Bluff Dale, Texas
Posted: 02/15/12 05:26pm Link  |  Print  |  Notify Moderator
Can remove sediment and hard water scale by draining. There is at least a quart of water left in the tank after you drain it. Siphon of flushing will remove it. Flush with the drain plug removed.
wolfe10
Posted: 02/15/12 05:59pm Link  |  Print  |  Notify Moderator
Yes, being heavier than water, the minerals will be in the bottom, below the drain plug. That is why we use a siphon to "vacuum" them out.
Just move the hose around the bottom of the tank-- with a clear hose, you will see when you do/do not have minerals in the hose.
If it hasn't been done in awhile, you may have to have someone "bump" the water pump to re-fill the heater if you couldn't get the whole thing clean in the one 6/10 gallons of water in the tank.
And, though it should be obvious, be sure to bleed off water pressure before removing the drain plug (unless you really need a bath and don't mind the plug being shot at you under 30 PSI!)
nbounder
Arizona mountains
Posted: 02/15/12 09:20pm Link  |  Print  |  Notify Moderator
One added thought - set your levelers to tilt the rig so the effluent pours out easier. Good idea, no?
Nbounder
KG7DKF
Learjet
Louisiana
Posted: 02/16/12 02:10am Link  |  Print  |  Notify Moderator
It works great for me, been using one for years.
2013 Ford F250 XLT 2wd Crew Cab 6.2 and 3.73 rear
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Yamaha EF2600c Tri-Fuel Gen.
Champion Model 46595- 3000/3500
sold* 2001 Hurricane 30Q Chevy workhorse
sold* 2006 Nissan Titan CC with tow package
