meesda
Bathurst NB
This products is exactly for this problem. It would probably also stop any wind flapping
www.awningairwedge.com/
Dant
2006 Cruiser CF29BT
2008 GMC Sierra 2500 Ext Cab 6.0
Dick_B
Palos Heights, IL USA
Throw a rope over the cover and tie it down at both ends forming a trough for the water to run out.
Haven't tried it but a piece of pvc pipe with holes along the length should drain it but how to get it up there and down again?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
fred42
Charlotte, NC, USA
I tried deflated beach balls, but that kept moving the pool to another area. Also, not sure how to put or retrieve a ball 5' into the slide. I had the best luck with swim noodles. Had to find the large 4" diameter ones. Then I measured the height I thought would work. In my case the distance required a sliced noodle. I used shrink wrap on a stick to hold the 3 noodles together because it is easy to undo if I needed to adjust something. Also didn't want sticky tape in the heat. The one long slide I have pooling with requires 2 long and 2 short pieces. Keeping the short pieces on the ends allows you to reach them for removal.
I suppose retracting your slide with one of these in would not be good. I made a hanging cardboard sign over the slide switch. I also have to check for open cabinets before I open a slide.
2001 F350 SC DRW V10 5spd 4x2
2012 Evergreen Everlite 31RKS-5
netjam
Canadian on the road
Have put up with this problem for years and tried all suggestions except the air wedge. All work with varying results. None are perfect. The problem with beach balls is that winds will blow them out. I put them in a mesh bag with rope attached to the bag that I tied to each end of the slide. Throwing a rope or belt over the slide and tying it down stretches the fabric...did that once and it made a real; mess. Currently using pvc piping and it works but again..not perfect.
JesLookin
Appleton,WI
I wait till it stops raining & then open & close the slide. All the water will runoff, allowing the cover to dry nicely.
2005 Sierra 285 BH
2003 Dodge 2500 Diesel, quad cab, short bed
Vulcaneer
Northern New England
I don't think the ponding is any problem. Stretching the fabric? Hasn't been an issue for me. But the ponding does leave a stain on the top of the fabric. But few people will ever see it.
If it really bothers you, closing the slide with occasional stops, will allow the water to escape. Or else raise the front of your trailer up a couple of inches to get the water to runoff the rear of the topper.
That is one of the nice things about an auto-leveler system. Very easy to push the button to raise the rear stab's so you can raise the front. And then just push the button to auto level again. Back to level and no water on the slide toppers.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto, Ultimate Lariat pkg
2011 Open Range 393RLS 14,250 GVWR
Pullrite Super Glide 18K
sailor53
Mesa, AZ
If they are on an older unit, you might look into torquing the retraction spring a bit to put more tension on the awning so it doesn't sag. Alternative is something under the awning to support it.
Lyle
If they are pooling water, the damage is done. The material in the center will stretch more than at the ends because the center doesn't have the stitching the ends have. Adding tension will only increase the force on the ends.
I would do as others have suggested and get some beach balls or make up something with PVC. JMHO
DW Barbara for 15 yrs
08 Ford F350 Lariat, PSD 6.4L, Ext Cab, 4X4, Line-X, DrawTite Signature 18K hitch, RDS 40 gal. Tank/Tool Box Combo, Mor/ryde RS suspension, Garmin Nuvi 465T GPS
09 Montana 3000RK, Mor/Ryde suspension/pinbox, Spendide 2100XC W/D
sailor53
Mesa, AZ
meesda wrote: This products is exactly for this problem. It would probably also stop any wind flapping
We tried these and they didn't work for us. The wedge wouldn't fit over the bedroom slide at all. We placed one over the living room slide and it worked fine but the wind continually blew it out.
Maybe others know something I don't to prevent the wind problem.
meesda
Bathurst NB
Thanks Sailor53,
Glad to get some feedback from an actual user. I was to order one for our slide unit but I will hold off for now. Might use pool noodles?
netjam
sailer53....I put a 2" wide strap over my Dometic/AE toppers. They do not have stitching on the edges (carefree does) and it stretched the******out of the edges of the topper. Like I said. it made a real mess out of that topper. I know some people do that and even add 90 degree PVC over the ropes they use. I never could get it to work though.
