1L243
Astoria, Oregon
I was wondering if anyone has added cables or other means so you can use your ramps as a deck? Where and how did you mount your cables?
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
jetboater454
Camping or home
Pic of mine. Link to other pics. Ramp patio
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
Sandia Man
Rio Rancho, NM
Ours came with a set of cables and factory installed connection points along with the patio room my DW wanted. We use our ramp as a deck quite often and will put up the ramp room on extended stays.
MadMav
Colorado Springs, CO
I did this on my Winners Circle. I used HD rated eye bolts and washers. Drilled the hole 3/4 of the way out the door in the aluminum frame. Then secured the cables to the upper door frame with HD clamps. It worked wonderfully.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
nayther
Burbank, CA
I have cables made but only used it once or twice. With mine if the beds are down it's not much use.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
1L243
Astoria, Oregon
Jetboater that is what I have in mind. Did those eye bolts bolt all the way through or screwed into the metal frame?
nvreloader
Western Nevada
My 2009 28KS Desert Fox TH came with the ramp door setup and a screened room that goes around the deck, plus the second (bottom) bed of the double beds in rear converts into a fold up couch that will face the inside or the outside deck area, depending on what you want.
Don
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
jetboater454
Camping or home
1L243 wrote: Jetboater that is what I have in mind. Did those eye bolts bolt all the way through or screwed into the metal frame?
Mine I ran all the way through,same on the top side,they come out the side of the trailer,I still need to install those plastic caps on the nuts.
LowRyter
OKC
I've attached my ratchet strap tie downs to level it and sit.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
wvabeer
West Virginia
I bough cheap heavy duty jack stands at harbor freight to hold it up. whala! a porch.
1992 Airstream 33'landyacht M/H
12 Arctic cat Wildcat
08 Arctic cat Thundercat
03 Kawasaki 650 Prarie
01 FLHTC
