RV.Net Open Roads Forum: Its been years since I've seen ignition keys
Search only in Tow Vehicles
 > Its been years since I've seen ignition keys
Dr Quick
M'boro, Tn
Posted: 02/16/12 03:12pm Link  |  Print  |  Notify Moderator
Most vehicles now use a computer chip, so the steering wheel lock is not necessary. The electronic key sounds good, but it raises a few questions.
The electronic keys are quite large, so what happens if you have three vehicles like I do. Since I never know which vehicle I need to have access to, trying to carry all three in your pocket would be awkward as they are very large in size.
If you loose a regular key you can get a copy for a few bucks, but if you loose the electronic key try several hundred dollars to replace it.
What happens if you are out in the boondocks, and the battery quits in the electronic key?
Dr Quick
Johno02
Lexington, TN USA
Posted: 02/16/12 03:35pm Link  |  Print  |  Notify Moderator
I would really like to see the dimmer switch back on the floorboard.
Noel and Betty Johnson
2005 GulfStream Ultra Supreme, 1 wife, 1 Poodle
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 02/16/12 06:15pm Link  |  Print  |  Notify Moderator
mkirsch wrote:
Tim_W wrote:
If you haven't purchased a vehicle in the last 10 years, you probably don't know that the key switch on the dashboard is back in style.
Heck, my 2003 Silverado doesn't have a steering column lock. I don't think anything has a locking steering column anymore. Makes them more difficult to steal by lifting from the rear wheels, be cause they're all over the place behind the tow truck.
Our 2010 Jeep Liberty has a column ignition switch and locking column. I'll take a walk out on the plant floor and see if any of the columns we build have a non lock option. BRB with an answer.
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
AUWing
Slinger, WI
Posted: 02/16/12 06:45pm Link  |  Print  |  Notify Moderator
My '37 3/4 ton has a crank-out windshield but the 6 cyl won't pull the Jayco
My '11 3/4 ton pulls fine but I wish it had a crank-out windshield
From someplace in SE Wisconsin
2011 Silverado 2500 Ext-cab / reg box / D/A
2008 Jayco Eagle 313RKS
2008 Goldwing
Perrysburg Dodgeboy
Posted: 02/16/12 06:55pm Link  |  Print  |  Notify Moderator
OK from what I was just told, if you have a column without a gear shifter your column does not lock. We install an aluminum cover over the lock opening to keep dirt and foreign material out of the column. I'm going to talk with an engineer tomorrow afternoon to double check this.
Don
Goatdog
Knoxville/Yorktown TN/VA
Posted: 02/16/12 07:12pm Link  |  Print  |  Notify Moderator
Most Toyota (except Prius)ignition switches are on the dash and not the steering column. Doesn't make it harder or easier to bypass vehicle immobiliser devices by thirves, but somewhat easier to repair.
DW, and 4/6 kids left in the house (last five are girls)
Zoey, the manic White German Shepherd
2010 Four Winds Chateau 28A
2006 Toyota Sequoia Limited 4WD
2004 Toyota 4Runner SR5 4WD (very modified)
2001 Toyota Avalon XL
1996 Toyota Tacoma SX
EPenney
Galt, Ca
Posted: 02/16/12 08:52pm Link  |  Print  |  Notify Moderator
Bought DW a new Avalon Limited for Christmas. First car for us that has No Key! Just a push button on the dash to start. Kind of cool when you walk up to the car at night, and it senses the fob, turns the door handle lights on, and then the interior lights. Just touching the door handle unlocks the car.
'07 Chevy 2500HD Silverado "Classic" CC D/A 4x4
'07 Komfort Trailblazer T252FS fifth wheel
Reese Signature 18K Slider and other stuff.....some useful.....some not
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/16/12 08:57pm Link  |  Print  |  Notify Moderator
My '69 Bronco has the ignition key switch in the dash, which was common for early body style Broncos. It doesn't have a steering wheel lock.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Fulltimers
Anywhere, USA
Posted: 02/16/12 09:04pm Link  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Dad's '63 Ford Econoline Pickup had the ignition on left side of dash
So did my 66 Datsun PU. That way I could turn the key with my left hand while working the manual choke with the right.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad)
Photos
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/16/12 09:07pm Link  |  Print  |  Notify Moderator
Don
My '98 Ranger has a stick shift on the floor, with a locking steering column, via the ignition key switch. Same with my old '87 Dodge Ram 50, '78 Chevy Luv, '79 Jeep CJ-5, '80 IH Scout II, '80 Toyota pickup, '81 Toyota pickup and likely a few others I have forgotten.
