RV.Net Open Roads Forum: Technology Corner: CD / DVD Drive disappeared ?--UPDATE
 > CD / DVD Drive disappeared ?--UPDATE
siggyd777
Northern Illinois
Posted: 02/16/12 11:14am Link  |  Print  |  Notify Moderator
My CD / DVD drive (D) no longer shows up in Folders,it takes and spins
the CD,but does not play it. It's a Toshiba ,Windows 7 (64)
Please help, I'm not a computer GURU
Thanks ,Siggy
* This post was edited 02/16/12 03:22pm by siggyd777 *
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2005 Saturn VUE AWD V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283 , NKK 17385
ArmySFCRet
Moving to Congress, AZ
Posted: 02/16/12 11:17am Link  |  Print  |  Notify Moderator
Either a driver issue or the drive itself has gone bad.
'04 Cross Country 35' w/300 Cummins
'05 Sebring CV on KarKaddy 460SS
'09 Dodge Ram 1500 4x4 Crew 5.7 Hemi MDS
'51 & '53 Hudson Hornets 308 6cyl w/TWIN H-POWER
5 lbs of BG the Yorkie
Members of:
Grand Canyon Chapter of Hudson Essex Terraplane Club Inc
exeter_acres
North of Atlanta, GA
Posted: 02/16/12 12:00pm Link  |  Print  |  Notify Moderator
Right Click on Computer or My Computer
Choose Properties...
look for a link for device manager
look for "DVD/CD Rom Drives"
click to open it.
if there is something listed there
right click on it and choose uninstall.
Reboot the computer..
should find it and re-install the appropriate drivers.
troll3193
SouthWest, MI USA
check this out. Have had to run through this on a toshiba laptop a while back...
http://answers.microsoft.com/en-us/windo........ive/20913383-9476-45d4-b112-660c728447f5
I ended up using the Mr Fixit route I think...
Ended up working just great
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
Don & Linda
Western PA / Cape Cod
Posted: 02/16/12 03:04pm Link  |  Print  |  Notify Moderator
Thanks ,Siggy
I have a Win7-64 bit pc and every time I install or update a driver stealer (i.e. I-tunes, Nero, Roxio...the same thing happens.
If above solutions don't help try this, but do so,carefully as it's non-reversible.
1 Click Start, and then click Run.
2 In the Open box, type regedit, and then click OK.
3 In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
4 In the right pane, click UpperFilters.
Note: You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
5 On the Edit menu, click Delete.
6 When you are prompted to confirm the deletion, click Yes.
7 In the right pane, click LowerFilters.
Note: If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
8 On the Edit menu, click Delete.
9 When you are prompted to confirm the deletion, click Yes.
10 Exit Registry Editor.
11 Restart the computer.
This always gives me my lost drives back.
Sorry if this post seems long, I lacked the time to make it shorter.
almost quote from S.L. Clemens
Don & Linda
1st RV UL EMS 4s Dome
2nd RV 21' AMF Scamper TT PV D300 Dodge
3rd RV National Seabreeze 133LX w/Demco Dolly
4th RV Jayco 2450 5TH PV Ford F-250 SD
siggyd777
Northern Illinois
Posted: 02/16/12 03:15pm Link  |  Print  |  Notify Moderator
Thank you all,Thank you "exeter_acres".
I did the Control Panel,Hardware & Sound,Device Mgr.,Dvd/CD-Rom,
HL-DT-ST-DVDRAM GA10F, UNINSTALL!
After boot up the driver installed successfully & automatically.
All looks good,the D-drive is back.
You guys are GREAT!
Siggy
