RV.Net Open Roads Forum: Class A Motorhomes: Bleeding brakes
 > Bleeding brakes
Stuck in first
Virginia
Posted: 02/16/12 01:38pm Link  |  Print  |  Notify Moderator
I have a 2000 Southwind gasser on a workhorse chassie with antilock brakes. Time to replace the fluid using a . vacume pump. Should I use dot3, dot4 or synthetic fluid? Is there anything special I need to do to address the antilock system?
rgatijnet1
Posted: 02/16/12 01:53pm Link  |  Print  |  Notify Moderator
I would use the fluid recommended by WH which for your coach it is DOT 3. It has worked since 2000 so why change? For the type of driving that you do, it will be fine as long as you buy a name brand quality brake fluid. You don't need to do anything special for a brake flush with anti-lock but keep in mind that any left over fluid is not to be used in your brake system in the future. Once the seal is broken, use it than dispose of the left overs.
harold1946
Surprise Arizona
Posted: 02/16/12 01:55pm Link  |  Print  |  Notify Moderator
The Workhorse chassis owners manual and the chassis guide both say to use only DOT-3.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
weathershak
Not sure, I need to look out the window
Posted: 02/16/12 01:57pm Link  |  Print  |  Notify Moderator
Use Dot 3 I used a turkey baster to suck the old fluid out of the reservior and filled it with new fluid before I bled the brakes. The M/C is in a fun place and a pita to get at.
Full timing it since July 2012 My pics
bugs53
Jacksonville, Fl
Posted: 02/16/12 01:58pm Link  |  Print  |  Notify Moderator
I don't know much about this subject but I do know that the DOT 4 Fluids have a higher heat point. Ie. condensation, boiling and etc.
I can't imagine why the 4's would not not be an improvment. All of the newer Gassers call for DOT4 only.
Bugs
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
Stuck in first
Virginia
Posted: 02/16/12 02:02pm Link  |  Print  |  Notify Moderator
Thanks for the replys. I'll go with Dot3. Any guess on the quantity needed?
rgatijnet1
Posted: 02/16/12 02:14pm Link  |  Print  |  Notify Moderator
A complete flush will probably use 3 quarts.
Weathertodd221
FL
Posted: 02/16/12 02:17pm Link  |  Print  |  Notify Moderator
can go dot 3 synthetic. Get one of those brake tools like this
http://www.amazon.com/Mityvac-MV6835-Vac........g/dp/B0015POUXM/ref=cm_cr_pr_product_top
Makes the job a breeze. You shouldnt have to removed the wheels either.
Stuck in first
Virginia
Posted: 02/16/12 03:14pm Link  |  Print  |  Notify Moderator
Thanks rgatijnet1
 > Bleeding brakes
