donandmax
Delta Co.
What would be a good brand of air compressor I could buy for my moho ? I'm thinking maybe of something from Harbor Freight.....
bugs53
Jacksonville, Fl
Any brand you can get 120psi will do the trick for a gasser with 19.5 tires. 225 or larger diesel coaches may require something a little more hefty. I have a smaller coach and carry a Sears, one tank, oil, 125 psi in my coach. Love the thing, no problems and check my coaches tires religiously,.
Bugs
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
hottubkid
SCHAUMBURG,IL
Check tires at the house
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
WyoTraveler
Northwest, Wyoming
I've been shopping for a dual purpose air compressor. One that will not only air up the tires but blow out the water lines to winterize. Plus operate on 12 Volts DC. So far I'm looking at the Smittybilt 2781. 12VDC good for 150 psi and 5.65 cfm of air. I have some questions in for the manufacture because I want to adapt the output to standard air hoses with disconnects. I also want to add my own pressure gauge so I can adjust it to not go over 45 lbs for blowing out the water lines.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
PapPappy
Wilmington, NC
Harbor Freight makes tools that serve a certain purpose.....and I've got lots of them, but I don't know if I'd use their compressor, because they are usually better if you are only going to use the tool a couple of times. If you have the storage space, I'd recommend getting something like a "Pancake compressor" like THIS one from Home Depot. It's rated to 150 psi, so should meet all our needs.
A bit pricier than HF, but a better made piece of equipment, and you will find that you use it more than you think....at home and in the RV.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
Tom/Barb
Oak Harbor
The best name in the business is " Campbell Van-Hausfield" (sp) pick your size and power requirements. they make a bunch of sizes. They make sears, Grizzley, and several other brand names.
but,,,,, if your coach has air ride you already have one aboard.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
FormerBoater
South Florida
This one has made my life much easier:
http://www.sears.com/shc/s/p_10153_12605_00915309000P?blockNo=10&blockType=G10&prdNo=10&i_cntr=1329498547653
Tops off my 22.5 tires, will run off my inverter and I can reach all six tires using a 20 foot extension cord.
Dave
1998 American Eagle 40EVS
Weathertodd221
FL
I got a small 1.5 gallon compressor from Dewalt (emglo).
Runs 130psi and with the adjustable regulator & clip on chuck makes filling 22.5 tires easy. Will fill a flat tire in 7 mins.
What I have noticed is when you have a long fill... it tends to condensate so I put a dryer between the compressor and air line. Plus its small and easy to carry.
This is it
http://www.factoryauthorizedoutlet.com/d........140.asp?gclid=COXGqqrCpa4CFYuc7Qodr2ItSg
2oldman
Winchester WA
This little guy is what I just got. Quiet. Most 120v "cheap" compressors are really loud.
12v compressor 2010
Compressor 2009
Compressor 2010
Compressor 2011
donandmax
Delta Co.
Think I'll go with the Porter Cable from HD
Thanks everybody
