RV.Net Open Roads Forum: Class A Motorhomes: Battery tender or disconnect?
 > Battery tender or disconnect?
wheelman16
Boulder City, NV
Posted: 02/17/12 02:05pm Link  |  Print  |  Notify Moderator
I use a battery tender to keep my chasiss battery charged and it does it's job but I have noticed bad corrosion on the positive terminal. Does anyone know why this occurs? Am I overcharging my battery by leaving the tender on all the time when not in use? And is it better to disconnect the battery while sitting for periods of time rather than charging it? Thanks, Bob.
Weathertodd221
FL
Posted: 02/17/12 02:09pm Link  |  Print  |  Notify Moderator
corrosion is not unheard off. You can clean it off and coat the terminal with the appropriate oil. If you have the quick disconnect plug make sure you dont get that oil on it.
old guy
Oregon (pronounced Or e gun)
Posted: 02/17/12 07:25pm Link  |  Print  |  Notify Moderator
pour hot water over it to clean it up and then take a wire brush to it , to finish it up.
FIRE UP
Ramona, CA. USA
Posted: 02/17/12 08:50pm Link  |  Print  |  Notify Moderator
wheelman 16,
I'm not really a battery tech and certainly don't know what causes the corrosion. I suspect it's from either a high rate of sustained charge or, there's a leak in or around a terminal, not sure. I've had my share of corroded terminals in the past and I hate that stuff. Our coach, an '04 Itasca Horizon D/P, is always plugged in at home. I've done some battery work in the last few months on both the chassis batts and the house batts.
Anyway, I didn't really have any corrosion before my battery maintenance and, like stated, it's been consistently plugged in since the work was done. I don't have any now what so ever and since I don't like any of that junk on my battery terminals and cable ends, they remain clean and nice. I take a look at them at least once a week and, all is well.
With a battery "maintainer" I would think that certainly you would NOT have an "over charge" condition that would cause boiling and therefore surface acid residue which, I think would enhance the corrosion properties. So, what's causing your condition, don't know. Let us know what you find out.
Scott
Scott and Karla
SDFD RETIRED
2011 White Honda CRV EX-L,4WD w/NAV Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
