RV.Net Open Roads Forum: Travel Trailers: Power plug
 > Power plug
DogTrainer
Tulsa, Oklahoma
Posted: 02/17/12 02:27pm Link  |  Print  |  Notify Moderator
I've noticed that my prongs on the plug are pitted a little and one is loose. What is the rule of thumb on changing those.
You ever change your plugs?
A fellow capmer said they get loose and then catch fire or melt
2007 Chevy 2500HD 6L Auto 4WD
2006 Keystone 29BHS
Wife and 2 great kids
2 labs
gktsuda1956
Washington
Posted: 02/17/12 02:47pm Link  |  Print  |  Notify Moderator
Which plug are we talking about?? Truck to trailer??? or trailer to shore power??
Glenn
Retired Navy Saturation Diver
2011 230RKS Wind River - Outdoors RV
2011 F-350 Crew Cab 6.7L Diesel Short Box
Longview, WA
old guy
Oregon (pronounced Or e gun)
Posted: 02/17/12 07:23pm Link  |  Print  |  Notify Moderator
some of the replacement ends are too big for the opening so You may have to put in another storage hole of a box with a locking door. The only one I could find even at home depot was too big for my little opening to store it out of the way. for a while I had to duck tape it to the side of the Tt when I drove down the road. I got tired of that and put in one with a larger opening.
ScottG
Bothell Wa.
Posted: 02/17/12 02:52pm Link  |  Print  |  Notify Moderator
I just changed mine after a trip to a CG last year where I had to use my AC a lot and the plug got fairly warm. I went with a Marinco plug because their products are good quality generally. The plug is solid brass and uses a crush style of wire connection rather than the poorer, "wrap the wire around the screw" type. I figured Marinco would be a better product than the Camco.
They also make a 50A plug.
Marinco 30A
* This post was edited 02/17/12 03:00pm by ScottG *
Scott, Grace and Wesly
H0NDA eu2000i
Bob Landry
Austin, texas
Posted: 02/17/12 03:02pm Link  |  Print  |  Notify Moderator
If they are anything but smooth, shiney and tight, replace them. They arc and cause burn marks and create resistance causeing the system to draw more current and the cord to overheat. The inlet on the trailer also needs to be checked and if threre is any discoloration indicating heat, replace it also, yo have some bad connections.
This problem can just about be completely eliminated by insuring the breakers on the pedestal are off when you plug into it. Plugging it in a live socket will always cause an arc.
2011 Tundra 5.7L
2011 Keystone Outback 277RL
beemerphile1
I'm 57, I'm not a
Posted: 02/17/12 06:53pm Link  |  Print  |  Notify Moderator
If you are talking about the shore power plug, you are past due. Change it immediately.
- Soren Kierkegaard
ggardne2
Livonia, MI
Posted: 02/17/12 11:18pm Link  |  Print  |  Notify Moderator
If pitted and loose I would change them before the plug overheats and melts or catches on fire. After changing the plug end, you may consider purchasing a 50 - 30 amp adapter if you camp with any frequency at campgrounds that have 50 amp plugs. Whenever the option is available I use a 50 - 30 amp adapter at campgrounds ... the 50 amp plugs do not get used as often as the 30 amp plugs do and the larger prongs are not as susceptible to over heating.
DogTrainer
Tulsa, Oklahoma
Posted: 02/19/12 07:53am Link  |  Print  |  Notify Moderator
thanks all, it was the trailer to shore power plug.
i am at fault for the pitting, most people dont realize that they need to kill the pedastal power by tripping the breaker before putting the plug in. will do in the future.
and i will order the plug you had recommended in the thread.
with everything else we talk about we never seem to discuss routine maintainence on the electrical system or plugs.
ScottG
Bothell Wa.
Posted: 02/17/12 07:42pm Link  |  Print  |  Notify Moderator
Oh thats a very good point I hadn't thought off. I have installed a 50A size door so no problem that way. That Marinco plug may be too big to get through the smaller hole. Too bad, it's a nice plug.
 > Power plug
