RV.Net Open Roads Forum: Towing: What temp is normal for transmission while towing?
Search only in Towing
Open Roads Forum  >  Towing
 > What temp is normal for transmission while towing?
DwnSth
SE Louisiana
Posted: 02/17/12 02:52pm Link  |  Print  |  Notify Moderator
I'm sure this will be different for each vehicle. Driving '07 Tahoe with 5.3 and 3.73 ratio and heavy duty towing package. I'm wondering what transmission temperature would be considered OK or not OK while towing. Normal interstate driving no trailer, 70mph degrees air temp at 70mph I seem to stay at about 175-180 degrees on transmission. Towing 4400 trailer at 60mph temp was running just over 200. I'm supposed to have a trans cooler (although I can't phsycally see it as I could on Expdition) but have no idea what 'normal' would be while towing.
2012 Aerolite 212RBSL
2013 F150 Lariat EB S-Crew max tow HD payload
1996 Four Winns Horizon 190 (gotta have a boat down here)
old - 1995 Jayco 1007 pop-up (lost to a fallen branch)
MitchF150
Washington, the State
Posted: 02/17/12 03:19pm Link  |  Print  |  Notify Moderator
Seems a tick high to me. Where are you reading the temp from? I've got aftermarket trans temp gauge and the sensor is on the trans output line, before it goes into the radiator cooler.
I see temps ranging from 180-210 while towing depending on the terrain.
Your cooler maybe tucked in behind the rad, just in front of the fan... Most are on the outside and can be seen thru the grill (mine is), but I've heard of them being on the 'inside' too....
You should be able to follow the trans line that comes out of the bottom of the rad and see where it leads.. If it goes straight back to the trans, there probably is no aux cooler...
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
therink
Rochester
Posted: 02/17/12 03:34pm Link  |  Print  |  Notify Moderator
I get 170 without towing and up to 205 towing. Vehicle information below
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
skipnchar
Topeka or somewhere else
Posted: 02/17/12 03:36pm Link  |  Print  |  Notify Moderator
200 would be about normal if you were climbing a grade on a warm day. Not apt to be dangerous to your transmission as long as it doesn't get a LOT hotter when you're actually working it. Working it hard on very hot days would usually get you somewhere around 220 or so. Your normal transmission temp will very depending on the ambient temperature where you're driving also.
Good luck / Skip
Golden_HVAC
Fulltime, CA, USA
Posted: 02/17/12 03:42pm Link  |  Print  |  Notify Moderator
Hi,
I agree that the transmission fluid is at the upper limit of deciding to do something or not. Sort of a gray area, if it was 220, I would say install a second cooler - one you can see, not just the transmission fluid to engine coolant cooler in the water tank. At 180, I consider that on the low side of normal, I would actually need to see it about 175 on each winter driving trip to consider that water will not condense in the transmission fluid, so it is ideal.
I would try towing something heavier - if you plan on towing something heavier in warmer weather to check and see if 200 is your "Normal" for that size trailer and it will only get warmer, of if the factory cooler will kick in better in warmer weather and stay at 200 all the time, even with a heavier trailer.
My thought is get a secondary cooler, and install it on the transmission cooler return line, and then you will have little to worry about. Yet because it is so close to the "Gray area" not doing anything will not provide bad results, until you tow something that is much heavier in 95F weather and the transmission starts to go above 220F. If you reach 230F, then the idea is to slow a bit to allow the engine to cool, and this will reduce the load on the transmission, cooling everything off. So if you are patient on he mountain grades, then you probably will not need the transmission cooler.
You can still tow up a grade with 235F peak transmission temperatures and it will not quickly degrade, however that is a very warm temperature for the transmission to be running at, and you should consider flushing the transmission after returning home. If you reach 250, slow way down, if it does not drop below 235 right away, consider your options to pull off the roadway into a wide area, and see if the transmission has a problem, or if the coolant line is leaking or broken. Yet with a hot engine, don't shut it off right away (this stops the cooling pump and fan) unless you have bigger problems such as leaking water or fluids.
Remember that it is increased horsepower that overloads the radiator and transmission cooler, so going up the mountains slower requires less horsepower, thus the engine is much less likely to overheat.
Fred.
tvman44
Southwest Louisiana
Posted: 02/17/12 06:14pm Link  |  Print  |  Notify Moderator
Seems a little high for the conditions you listed, I'd install a aux cooler.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
MARKW8
Akron OH
Posted: 02/17/12 06:28pm Link  |  Print  |  Notify Moderator
200 is no problem towing. Like above 220 is getting too much. If the trans has never been serviced, you should do that. It would be a good idea to have synthtic fluid put in. It will tolerate more heat without breaking down.
Mark
overdrive75
Whitmore Lake, MI
Posted: 02/17/12 06:42pm Link  |  Print  |  Notify Moderator
That temperature sounds right on the money for a 4L60E towing. I wouldn't worry about it at all.
2002 Chevy 2500HD 4x4 6.0L 4L85E 4.10 Full Floater 9200GVW 16K GCVW
2009 Rockwood Roo 23SS for camping
1989 Searay 230CC for the weekends when not camping.
ib516
Up here!
Posted: 02/17/12 07:48pm Link  |  Print  |  Notify Moderator
I think it's normal, and I wouldn't worry about adding additional cooling.
I don't mean to sound like a smart guy, but have you checked the owners manual? maybe they mention a "range" in there. I have recently added a digital trans temp gauge to my truck, but haven't towed with it installed yet, thanks to my location here in the Great White North . My truck runs about 180-185 non towing.
* This post was edited 02/17/12 08:40pm by an administrator/moderator *
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Indiandy
NWI
Posted: 02/17/12 09:09pm Link  |  Print  |  Notify Moderator
I have the same 07 tahoe, 3.73 gears. Same temps, except when it was 100+ outside in the middle of the day, and then not over 215. towing a 6500lb jayfeather in the midwest.
For some reason, I'm thinking that if you also have 3.73 rear gears, you do not have the hd tow package that came with the 4.10 gears. Your codes in the glove box will tell.
I am planning on putting in the GM trans cooler this year.
