RV.Net Open Roads Forum: Class A Motorhomes: A fire beneath the Fridge
 > A fire beneath the Fridge
zaitzcj
Rogue River, Oregon
Posted: 02/17/12 05:31pm Link  |  Print  |  Notify Moderator
I had electrical problems: one circuit kept tripping breakers. Took techs quite a while to find the problem: a 110 junction box beneath the refrigerator had shorted out, and burned part way through. Boy, are we lucky it didn't burn the place down. Some points here: Fleetwood puts all their electronics (converter, breakers, climate control) under the fridge. Now isn't that stupid? Of all the places in the MH where there may be moisture this would top the list.
And the second stupid thing Fleetwood designers did was put a 110 wire junction in a PLASTIC box. If it had been metal, as seems reasonable, the arcing wires would never have burned through. This is a 2000 Fleetwood Pace Arrow Vision we're talking about.
rvrepairnut
bc
Posted: 02/17/12 05:44pm Link  |  Print  |  Notify Moderator
most all the 120V outlet boxes are plastic on most all motorhomes
Its 12 years old.stuff gets worn and moved around etc
RV manufacturers do many many stupid things i have found over the years.
Iam curious as to what does this climate controll system you found under your fridge do??(whats it for)
Gale Hawkins
Murray, KY
Posted: 02/17/12 06:28pm Link  |  Print  |  Notify Moderator
Could this be the "cause" of some 'frig' fires?
FormerBoater
South Florida
Posted: 02/17/12 06:36pm Link  |  Print  |  Notify Moderator
Sorry about your issue, glad you discovered it in time.
FWIW, my Fleetwood has only a drawer for pots and pans under the fridge.
Dave
1998 American Eagle 40EVS
Dale.Traveling
Newport News, VA
Posted: 02/17/12 06:43pm Link  |  Print  |  Notify Moderator
I don't think are too many good places for it. My AC to DC convertor, Shore/Generator transfer switch and AC breaker panel is under the bed. Lot more stuff to catch fire there then a fridge. I would speculate that 75% of everything in a coach will burn and I think my estimate may be a bit lite.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
Jerry B
Lake of the Ozarks
Posted: 02/17/12 06:46pm Link  |  Print  |  Notify Moderator
Homes are full of plastic electrical work boxes.
Jerry B
Mobile Suites 36TK3
johnsonbert
Houston, TX-Ironwood, MI
Posted: 02/18/12 08:59am Link  |  Print  |  Notify Moderator
Plastic will not conduct heat or electrical current, so it will not get hot enough from the heat of a direct short to ignite a wooden surface next to it and it will not allow current to jump to another metal item that is may be in contact with.
Most homes over the last 15+ years use plastic junction boxes for lighting, switches, outlets and junctions.
In the 99 Pace Arrow and 2000 Bounder we had, the electrical components and transfer switches were located in a compartment above the fridge and had to deal with the heat escaping from the fridge vent area, which was substantial.
Redo the connection and replace the box with another plastic or Bakelite one. I would suggest checking other connections held together with wire nuts that area accessible. Hope this may help, Happy Trails Bert
2003 American Tradition 40W 350 Cummins
2010 Chev Malibu LT
rvrepairnut
bc
Posted: 02/17/12 07:21pm Link  |  Print  |  Notify Moderator
again I ask you? what is this climate controll under the fridge all about
Whats it for?
Carvin Marvin
Livingston, Texas, USA
Posted: 02/18/12 05:12am Link  |  Print  |  Notify Moderator
My Fleetwood also has a drawer under the fridge and under the drawer is the converter and of course a junction box. Have too look, I don't recall if plastic or metal.
barlow46
Edgewater, FL
Posted: 02/17/12 07:08pm Link  |  Print  |  Notify Moderator
Did you determine why the "shorting out" happened?
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
