RV.Net Open Roads Forum: Class A Motorhomes: Installing A Domestic Refrigerator
 > Installing A Domestic Refrigerator
lonnie4801
Posted: 02/18/12 12:58pm Link  |  Print  |  Notify Moderator
I know some have upgraded your RV refrigerators with domestic refrigerators. I am seriously considering it for my 2007 Holiday Ambassador. If you have done so could you please share with me the following information:
1. What make and model did you install?
2. Will it run on a modified sine wave inverter?
Thanks
2007 HR Ambassador 40'
2015 Colorado Z71 4x4 Crew Cab
West Texas, Retired
Fulltimers. No more grass to cut, no more leaves to rake, and can move if we don't like our neighbors.
Have driven or camped in 49 states. Have camped in all Providences in Canada.
enblethen
Moses Lake, WA
Posted: 02/18/12 01:26pm Link  |  Print  |  Notify Moderator
What is the make and model of the one you want to replace? That would help on knowing what size of Dometic you would be able to fit your opening.
An '07 really shouldn't need a new unit. What is wrong with the one you have?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
docj
Fulltime--Home is where we park it
Posted: 02/18/12 01:32pm Link  |  Print  |  Notify Moderator
Many of the people who have installed residential refrigerators, including us, have used Samsung's because the company has publicly stated that they will run on a modified sine wave inverter: Samsung Q&A That's not to say that other brands can't be used but it's nice to know the manufacturer doesn't object.
We used the model RF197 which is a counter-depth French door model with the freezer on the bottom. It is the same width as the 12 cu ft Norcold (the 4 door model), but it does require about 6-8 inches more vertical clearance. Because it is counter depth it doesn't project into the room any more than the old one did.
We're thrilled with the conversion and consider it the best improvement we have made to the MH--more space and the ice cream stays frozen.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
sailor_lou
Connecticut
Posted: 02/18/12 01:54pm Link  |  Print  |  Notify Moderator
The Samsung response is interesting in that they discuss the power supply being rectified, which is typical for the electronic circuits, but say nothing about the compressor and/or fan motor. I would doubt they are DC motors, but really do not know. This is not to say the refer will not operate properly with a MSW source, but I'm not sure they completely answered the question.
In any case, I will most likely follow your lead and do a similar swap if my Dometic fails. Thanks for the model number.
Lou
05 Travel Supreme Envoy
ScottG
Bothell Wa.
Posted: 02/18/12 04:02pm Link  |  Print  |  Notify Moderator
Any traditional fridge will run off a MSW but the motors will run hotter than with a PSW. Whether this shortens the life of it or not remains to be seen.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
lonnie4801
Posted: 02/18/12 03:19pm Link  |  Print  |  Notify Moderator
To docj - Thanks for the reply. I have been looking at the Samsung but as of yet have not found anything that will fit.
To enblethen - I asked a very specific question. If you don't have anything to contribute pleae mess up someone else's post and leave mine alone.
docj
Posted: 02/18/12 04:30pm Link  |  Print  |  Notify Moderator
The question asked of Samsung in that Q&A was:
Will your electronically controlled refrigerators such as RF197ACRS run properly on 120VAC 60hz MSW(Modified Sine Wave) electricity?
I assume that if something works "properly" both its electronics and its motors would perform acceptably. If Samsung wanted to caveat that they could have or they could have removed this Q&A if they had other concerns.
About 6 months ago they did put a caveat on another answer about use in an RV and they pointed out that the fridge is rated at a total starting current of ~11A. They state that an inverter needs to be able to handle the starting current, but they didn't retract the overall approval statement.
othertonka
Stockton, CA
Posted: 02/18/12 04:38pm Link  |  Print  |  Notify Moderator
I almost made the same mistake that you did. The Poster was asking about a "DOMESTIC" household refer not a Dometic RV refer
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
enblethen
Moses Lake, WA
Posted: 02/18/12 04:49pm Link  |  Print  |  Notify Moderator
I miss read the post.
No need to go off.
JFC
Northern California
Posted: 02/18/12 05:02pm Link  |  Print  |  Notify Moderator
Had a Dometic in our 2007 Scepter. Ice maker never worked well, and unit started performing poorly on electric. Had it replaced with 19.7 cu ft Samsung at Oregon MotorCoach Center last October. Works great, love it.
