RicJones
So. Cal.
I have a Demco tow bar and sometimes it's a PIA to get the arms to lock in. I have to move the toad forward and back and cut the wheel right and left sometimes before both arms lock in.
Those of you with Blue Ox and Roadmaster, what do you have to do, just drive away and they lock in automatically???
Dutch_12078
Great Sacandaga Lake, NY
That's the way my ReadyBrute tow bar works. After I've driven a few feet to let everything align and lock, I do go back and check that everything is as it should be.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
ernestfortier
Palmdale, Calif.
The instructions on the Blue Ox say to hook up and back the tow vehicle up until the bar locks. Sometimes only one locks until I drive off. Then the second one locks every time.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
othertonka
Stockton, CA
I have roadmaster, I hook up and then back up the toad until at least one bar locks, then after everything else is done, I just start out with the MH very slow and the second bar will lock in almost right away, you can feel it. Just make sure that you do the required maintenance on the tow bar as per the manufactures instructions.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Popsie
Livingston, TX, USA
Have you tried (partial) disassembling, cleaning, applying anti-sieze compound then reassembling as recommended by DEMCO?
OldF**t
Crossville, TN
Popsie wrote: Have you tried (partial) disassembling, cleaning, applying anti-sieze compound then reassembling as recommended by DEMCO?
+1 That's the fix.
Jim
2004 Hurricane 32R (F53)
Demco Excalibar
2010 Ford Ranger 4X4
2009 Kymco Xciting 500Ri
1 wife and 7 cats
RicJones
So. Cal.
Quote: Have you tried (partial) disassembling, cleaning, applying anti-sieze compound then reassembling as recommended by DEMCO?
No, I keep saying I'm going to have them rebuild it when I go to Quartzsite but haven't, it's just too heavy to lug to the tent.
I haven't checked, does Demco have something on their website about how to service it?
RicJones
So. Cal.
So far it sounds like with all the bars you have to go through the same basic setup. I was hoping one was simpler than the others.
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
RicJones wrote: I have a Demco tow bar and sometimes it's a PIA to get the arms to lock in. I have to move the toad forward and back and cut the wheel right and left sometimes before both arms lock in.
Ric,
My Blue Ox arms extend as I drive away.
Typically after hitching the toad, I push it back by hand to see if they lock. My experience is one will lock doing this and the other locks driving away. I sometimes need to cut back and forth too to lock it extended.
I have a microphone on the rear camera of the coach, I turn up the volume on the screen in the cockpit and listen for it to lock in; it's a very distinctive sound. I then check the image to see if the arms are clearly extended.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
phillyg
Front Royal, VA
x2. If mine was not cleaned regularly, one of the bars would fail to lock most of the time.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
