RV.Net Open Roads Forum: Class A Motorhomes: As requested, Red Max Pro instructions
 > As requested, Red Max Pro instructions
4x4van
California
Posted: 02/19/12 09:53am Link  |  Quote  |  Print  |  Notify Moderator
This has been posted before, but it tends to eventually get lost and covered up by newer posts. However, some have requested it again, so here it is. I do not recommend this for a newer MH with a good finish, or with full body paint and/or clearcoat that still shines and still responds well to waxes and polishes. This process is for older RVs that have lost their shine and no longer respond to conventional wax.
Restoring the finish of an older RV using Red Max Pro:
Materials:
-Red Max Pro (Step 3) Low Maintenance Floor Finish* (available only at Lowes, about $16)
-Bar Keeper’s Friend (powdered)
-TSP (Trisodium Phosphate, powdered)
-3M scrubbies (white, fine)
- Microfiber rags (white or laundered)
-Latex gloves
* If you can’t find Red Max Pro #3 at Lowe’s, Home Depot sells the same product under a different name for slightly more money. It is Zep Wet Look Floor Finish (Step 3), about $25. (Both are made by ZEP.)
Preparing the surface is the most important part, since anything left on the surface will be sealed under the Red Max Pro acrylic coating, and improper prep can also result in peeling/flaking later. I repeat: The prep-work is the most important part! Do not try to cut corners here. The cleaner your RV is, the better your final results will be.
Step 1: Start by washing your RV well as you normally would, making sure to include the roof, and rinsing well from the top down.
Step 2: You now want to remove any and all stains, soiling, oxidation, and chalkiness from the surface. Dip a white 3M scrubbie into water and then liberally sprinkle Bar Keeper’s Friend (BKF) on it. Scrub the surface of the motorhome, rinsing the scrubbie and re-applying the BKF often. Do small areas at a time, rinsing well with water and a sponge as you go (Rinsing well is important to remove all BKF residue. I used a "flow-thru" brush attached to a hose to rinse the BKF residue thoroughly).
Step 3: Next you want to make sure that there is absolutely no remaining wax on the RV, since any residual wax can cause the Red Max to peel and flake. Mix up a bucket of TSP (1/2 cup) in water (2 gal), and use it to wash the entire RV again. You can use it with a carwash brush, a sponge, a pressure washer…anything you would normally use to wash your RV. Rinse well as you go, then rinse again and let it dry completely (again, rinsing well is important to remove all TSP residue). You should now be left with a clean and smooth (although dull) wax-free surface. Congrats, the hard part is done!
Step 4: Now comes the easy part. Shake the Red Max Pro (RMP) well, and pour some into a shallow container (a pie pan works well). Fold a microfiber rag to about hand-sized, dip it into the RMP (trust me, use gloves!), and squeeze out the excess. How much/how wet? You want it more than damp, but less than dripping. Now simply wipe down the surface of the RV with the wet microfiber rag. Don’t try to apply a heavy coat or try to “rub it in”; just wet the surface (imagine wiping off a layer of dust with a damp rag). It really doesn’t matter whether you wipe horizontally, vertically, or in circles, and don’t worry about overlaps; RMP is very thin/watery and you are just trying to “moisten” the surface. Work your way all the way around the RV. The thin coat of RMP will dry very quickly; long before you’ve gone all the way around it will be dry and you can immediately start on the next coat.
That first coat will likely look really bad; streaky, blotchy, shiny in some places, dull in others…don’t panic. Each additional coat will start to even it out and build up a deep layer of shine. By coat 3, you will be grinning ear to ear. And coat 4 (or 5?) will be the icing on the cake. Not only will your RV shine like it hasn’t shined in years, it will be a deeper color as well*. Even old, faded graphics will have a new lease on life! All for less than $30 total!
*Note: This procedure will slightly change/darken the color/shade of your RV.
Things (I learned) to keep in mind:
-Don’t use new colored microfiber rags until they have been laundered, as the color may bleed.
-Don’t try to “over-apply”, or try for a heavy coat, or you will get runs. The thinner, the better. Remember, you’re just trying to “moisten” the surface with each thin coat, nothing more. If you are getting a lot of runs, you’re applying it too heavily.
-Be careful around window frames, locks, latches, etc., as the RMP is very watery and will have a tendency to gather and cause runs. RMP dries fast, so keep an eye out for any runs and give them a quick wipe before they start to “set up”.
-Some older, deteriorated graphics may “bleed” color onto the rag and surrounding areas. If you notice any bleeding during the BKF or TSP stage (steps 2 and 3), then give a quick wipe of RMP across the graphics prior to step 4, which will seal them up. Then go ahead and apply the RMP to the entire RV (including the now sealed graphics) as per step 4 of the tutorial.
-After each coat, go around and open/operate all hatches, locks, catches, etc. The RMP acrylic coating can sort of “glue” them closed.
-You can also do the window frames (avoid the glass) and other painted metal areas; in fact, I did my entire Class C cab since, like the rest of my RV, it was also very weathered and dull. Came out great!
Maintaining the Red Max Pro finish:
Now that your RV looks like it has a new, clear coated paint job, you’ll want to maintain that new finish as long as possible, right? Well, good news. With Red Max Pro, that’s easy to do as well.
Most commonly used car wash soaps and mild detergents will not harm the Red Max Pro finish, so you can wash your RV as you always have. In fact, you’ll probably find that it comes clean much easier than before, as dirt, bugs, and debris seems to “float” right off quite easily. You do want to avoid anything with Ammonia in it, such as some window cleaners, since ammonia will remove the Red Max Pro (think “floor stripper”). The tire cleaner spray at coin-op carwashes has also been shown to remove RMP. Minor scratches or blemishes in the RMP finish can be touched up easily with a quick coat or two of RMP. Do not apply wax, as wax will interfere with any “touch-up” coats of Red Max Pro later on down the road, causing them to peel or flake.
And after 6 months to a year, if the finish starts to lose it’s shine, just give the RV a good wash job, let dry completely, and then give the RV a quick touch-up coat or two of RMP, wiping it on just as you did originally.
Disclaimer: This procedure worked wonders on my weathered, oxidized RV, using the products and steps listed above, and I have no regrets. Hundreds, if not thousands, of others have also used RMP with similar results. A very few reports have surfaced claiming "yellowing" or "peeling", but most, if not all, of those have been attributed to improper surface prep. However, these products are admittedly not designed or marketed for use on the exterior of RVs, and I make no warranty regarding their use or the long-term effects on your RV. Use at your own risk.
A few final notes:
Some people have voiced concerns about the chemicals used in the prep stages. Bar Keeper’s Friend (BKF) is similar to scouring powder, but much less abrasive. In fact, it is made for cleaning and polishing fiberglass. Used with the fine white 3M scouring pads, it is excellent for removing stains, oxidation, and chalkiness from fiberglass gelcoat without scratching.
Trisodium Phosphate (TSP) is indeed a very strong cleaner. While it works very well to remove wax from the RV, it can burn if mixed too strong or left on your skin too long. If you are not comfortable with the TSP, some have reported good luck using Dawn dish soap to remove the wax.
Ultimately, neither of these products (BKF, TSP) are required. What is required is to remove all stains, soiling, oxidation, chalkiness, and wax from the surface of your RV prior to applying Red Max Pro, and to make sure that it is rinsed well to remove any residue of what you DO use. Whatever methods you are comfortable with are fine, as long as they accomplish that.
If your RV still looks good, and still shines...then use a good quality wax. But if your RV has deteriorated and you are looking for a way to breathe new life into it, RMP is an option for you. Go ahead, Google it. Read up on it. Read about those who have actually used it. Then make your decision.
* This post was last edited 03/02/12 12:15pm by 4x4van *   View edit history
We don't stop playing because we grow old...We grow old because we stop playing!
1988 Fleetwood Jamboree S26 27'
Carson enclosed ATV Trailer
'85 ATC250R (2), '85 BW200, '07 TRX400EX
Zieman Watercraft Trailer
'96 GTi, '96 Waveblaster II, '95 FX1
sch911
Rochester Hills, MI
Posted: 02/19/12 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Many people have reported that RMP #3 is no longer available at Lowes. There is talk of a similar product by Zep which is available at Home Depot.
Also, I do not agree with using any kind of abrasive pad. But rather a magic eraser pad or any zero abrasive pad. I didn't use any TSP either just Bar Keepers Friend only....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
gbopp
The Keystone State
Posted: 02/19/12 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Great instructions, thanks.
I also use RMP3 on the black rubber seal for the windshield.
I have not seen RMP3 at any of the local Lowes for at least a year.
4x4van
California
Posted: 02/19/12 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it seems to be hit or miss finding RMP at Lowes, depending on where in the country you are. That's why I also listed ZEP Wet Look, available at Home Depot.
Nomadac
Columbus, IN
Posted: 02/19/12 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the thorough instructions.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
J Walker
Oakton, Va
Posted: 02/19/12 11:13am Link  |  Quote  |  Print  |  Notify Moderator
I will just add that you can't get the coats of RMP too thin. In spite of trying to do so I still got some uneven spots. Not a big problem but I will be more careful next time.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
kcstepp1992
Indiana
Posted: 02/19/12 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you thank you thank you. Very useful instructions. I have an older motor home and am very happy to have a good set to follow.
garry1p
Oklahoma
Posted: 02/19/12 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Just what I was looking for.
Thanks;
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
fortytwo
Livingston, TX
Posted: 02/19/12 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Easiest way to avoid runs is to put the RMP in a good spray bottle and spray it onto a microfiber cloth. Then wipe on. No runs. No overspray that you miss and find later when it's dry. You get really thin coats this way. For me a good shine results at 4 but I normally add a 5th coat since I've got it prepped and an additional coat takes minimal effort.
Wes
"A beach house isn't just real estate. It's a state of mind." Pole Sitter in Douglas Adams MOSTLY HARMLESS
deandec
Northern CA
Posted: 02/20/12 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Great instructions. Thanks.
How difficult is it to Remove red max pro #3 or Zep wet look if one does not like the result a few months or years down the road?
Dean
95 CC Magna, Jeep GC
