Concordriver
SoCal USA
I have a 2008 Chev HHR that Im getting ready to tow. Ive read alot of old posts about Ready Brake, but nothing new, and it sounds like it would work for me,but the installation under hood could be too tight.
Anyone out there use a Ready Brake in a HHR? Any drawbacks? Problems?Does it perform as advertised? Thanks for any extra info youd like to give. Also you might comment on the Ready Brute Tow Bar if you have one, pros and cons. Thanks CONCORD
pulsar
Lewisville, NC
Moved from Forum Technical Support.
mm047
Green Valley, AZ
I've been really happy with my Ready Brake towbar and braking system used to toad my '10 Mercury Mariner. I installed it all myself 2 years back, and remember that threading the brake cable under and thru is awkward but then works out great.
I can't respond to your HHR difficulty, but would suggest you call Tow Bars Unlimited and talk to them about it. When I got mine from them they were most helpful. I've got to believe they can advise you on the HHR. Good Luck.
www.towbarsunlimited.com
Mile M.
2008 Winnebago View 24J
2010 Mercury Mariner
Ready Brute Elite and Blue Ox
golfknut
SW Michigan
We like our Ready Brute Elite towbar very much. It's well built and the integrated brake system works fine.
Our Ready Brake system is intalled in a Honda Fit, which has a very tight engine compartment. We had a local RV dealership do the install.
2005 Jayco Granite Ridge 3100SS
Peterrrrr
Ottawa
I installed the complete Ready Brake package on a 09 Chev Cobalt. I used the Demco baseplate. The braking components under the hood were very straight forward, as the work was under the engine compartment. Did the install myself with my BIL. The province I live in uses a front license plate, so I went directly through the plate with the install. I also purchased the complete package from Tow Bars Unlimited. Very good company to deal with. Did the install in the spring of 2010. Have towed the car across North America and back. Gone through the Rockies and the system works as advertised.
Took me longer to run the wiring on the Cobalt, for the rear tail lights. It was a harder job.
tropical36
Southwest Florida_USA
I'm considering this system and associated installation for towing our 2010 Jeep Wrangler 4 door. Anyone with a wrangler that has done this install? Also wondering if the firewall behind my brake pedal is single or double wall thickness?
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350 on a 1997 Chevy P32
Chassis_7.4 Vortec Engine_4L80E Tranny_slide_tag axle.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
doc brown
Redondo Beach, CA,
tropical36 wrote: I'm considering this system and associated installation for towing our 2010 Jeep Wrangler 4 door. Anyone with a wrangler that has done this install? Also wondering if the firewall behind my brake pedal is single or double wall thickness?
I did it. The wall was esay to penetrate - not sure if double or simgle wall - I do have more engine noise. Entire install was about 1 hr.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
tropical36
doc brown wrote: tropical36 wrote: I'm considering this system and associated installation for towing our 2010 Jeep Wrangler 4 door. Anyone with a wrangler that has done this install? Also wondering if the firewall behind my brake pedal is single or double wall thickness?
What year Wrangler? According to the instructions, you drill a pin hole and if double wall, then you move over to another location. If you didn't have any problem attaching the cable assembly at the preferred location, then I would assume single wall at that point.
Any comments on it's functionality and assume you're satisfied with it?
The 4 door Wrangler is fairly heavy and I don't have a coach such as yours to drag it around with, but from what I've seen going up and down the road, I should be fine.
MARKW8
Akron OH
I did my 08 Wrangler. The wall might be single but there is an aluminum heat shield on the outside.
Mark
Roadtech
Georgia
I have the Readybrake and I tow a 2006 Jeep Liberty behind a 27' Class C. The only problem I have encountered is a considerable amount of side to side swaying of the Liberty when going down the road. I had a guy in a truck pull up beside me while going down the interstate and roll down his window and yell that the Liberty was moving 6 feet side to side (I know he was exaggerating, but it did scare me). When I got home I checked and found the fit was fairly loose between the tow bar and the receiver end on the Readybrake. There also was some looseness on the other end where the Readybrake fits into the motorhome receiver. Since you are adding about 13 inches of length to the combination of the Readybrake and the towbar and two loose fits, you end up with a good bit of play at the Liberty connection. I am going to try installing one (or two) of the Roadmaster "Quiet Hitch" brackets to see if it tightens up the play. I hate to have to do this as it adds another complication to installing the towbar/Readybrake every time.
