RV.Net Open Roads Forum: Fifth-Wheels: fluoresent lights
 > fluoresent lights
kardar2
Redding CA
Posted: 02/19/12 06:47pm Link  |  Print  |  Notify Moderator
Hello,
On 12v flouresent lights do you have to buy special to 12v bulbs?
I bought some a home depot but they don't work. Thanks
dbbls
Missouri
Posted: 02/19/12 06:51pm Link  |  Print  |  Notify Moderator
Nope. Any bulb will work. I buy mine at Walmart and they work fine.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
ausie607
white lake
Posted: 02/19/12 07:26pm Link  |  Print  |  Notify Moderator
Rockintom brings up a good point. On the other hand any 12V should work OK. Take a moment and find the label and model just to be sure. Could be a transformer problem.
kardar2
Redding CA
Posted: 02/19/12 07:38pm Link  |  Print  |  Notify Moderator
I looked at the ballast and it is a darn computer board. It attached to the fixture and no way of takingit off
othertonka
Stockton, CA
Check the voltage in your battery. If it is below 11.7 or there abouts, the 12 V flourecents will not work. Try a fully charged battery before you give up and also make sure you have voltage at the light itself. I have one flouresent light that has a switch on it just like all the others, but it also has a wall switch. If the wall switch is OFF, the switch on the light will not work. does this light perhaps have another switch somewhere? Just a thought. And yes the bulbs you buy from Home depot or Lowes should work. That is where I bought mine.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
rockintom
Livingston, TX
Posted: 02/19/12 07:21pm Link  |  Print  |  Notify Moderator
kardar2 wrote:
Hello,
Actually the flourscent works on the 12V system, but the ballast converts it to 24V. As long as the wattage and length of the tubes are the same, you'll be good.
One thing to remember with flourescent lights in an RV....since the 12V gets converted to 24V....it is rough on both the ballast and bulbs if the batt(s) run low on voltage. Always something to remember when boondocking or anytime without shore power. Are you sure you haven't done that and wiped a ballast out? rockin'
Rockintom
'12 Excel Limited GKE 33 ft., trailer named "Charm"
'05 1 ton Chevy DRW Max&Allie Racor 660 Aux. Fuel Filter
Line-x Reese 20K hitch Prodigy controller GM nurf bars and folding bed cover - truck named "Tug" Fulltiming
kardar2
Redding CA
Posted: 02/19/12 07:55pm Link  |  Print  |  Notify Moderator
Hmm yeah there is a switch on the wall and there is a switch the on the lilight it self I tried both of those that BUT! THERE. A LIGHT SWITCH by the door of the trailer the wife and I tried to figure out what it went to. Maybe that's my problem.
othertonka
Stockton, CA
Posted: 02/19/12 08:05pm Link  |  Print  |  Notify Moderator
That is where my wall switch is also, by the entry door so you can turn the light on when you enter. Now if you turned it on by the door when you came in, but turned it off at the light, It won't work again from the door switch when you enter again. Give it a look.
 > fluoresent lights
