RV.Net Open Roads Forum: Tow Vehicles: Ford Ecoboost Control ?
Search only in Tow Vehicles
 > Ford Ecoboost Control ?
Page of 6
shum02
Burlington ON CDA
Posted: 02/23/12 02:51pm Link  |  Print  |  Notify Moderator
SeaRayder wrote:
shum02 wrote:
SeaRayder wrote:
NewsW wrote:
If you get a F-150, you get 150 rated tires, axle, frame.
Not True in all cases. The HD Payload option upgrades the tires to E rated,Wheels to 7 lug, Axles to 9.75" semi-floater, Frame is thicker .150", as well as a bigger radiator, trans, and oil coolers, heavier springs, HD shocks, and HD Bushings and bearings. Basically addressing all the concerns listed above
This is only av on the regular and SuperCrew models NOT the CrewCab - unfortunatly.
Wrong, The Max Payload is available in regular, supercab, and supercrew body styles. My 2012 F-150 Lariat Supercrew max tow and max payload 4x4 157" WB truck was built on 2/13 in KC and is being delivered any day now. Dont believe me? here is my Window Sticker.
Could not build one online without an 8' box which is only av in SC and reg cab configs - guess the dealer has more access/options than the online build sheet.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
goducks10
There
Posted: 02/23/12 02:57pm Link  |  Print  |  Notify Moderator
HD package is;
Reg cab 8'
Scab 8'
SuperCrew 6.5'
No other configs are available.
NewsW
US
Did you build it online in Canada? Or via a Canadian IP?
Big difference.
TurnThePage
North ID
Posted: 02/23/12 03:00pm Link  |  Print  |  Notify Moderator
The 8' box is for XT and XLT standard and supercab HDs. You can get a Lariat shortbox supercrew HD.
2015 Ram 1500
2004 Pioneer 18T6
shum02
Burlington ON CDA
Posted: 02/24/12 05:23am Link  |  Print  |  Notify Moderator
So the HD is not av in XLT/XL 6.5' boxes but is av in a Lariat and up trim short box? Let me build a Lariat.
Yup I can build an HD EB Lariat CC but can not build a XLT CC EB HD. Well that's just wrong, but it's not to say a dealer could not.
APT
SE Michigan
Posted: 02/24/12 06:41am Link  |  Print  |  Notify Moderator
That's a little weird, shum02. 2012 is the first model year Ford is offering a the HD paylaod (8200 GVWR) package with the crew cab. In the States it is XL/XLT/Lariat Regular or Supercab with 8' beds or Supercrew 6.5' beds.
2017 Subaru Outback 3.6R
spud57
Stratford PE
Posted: 02/24/12 09:12am Link  |  Print  |  Notify Moderator
If I had a towing question regarding a 1/2 ton pulling anything bigger than a pop-up, this would be the last place I would ask.
Why is it acceptable to hook up a 13,000lb 5th wheel to a SRW 1-ton but it isn't acceptable for an F150HD EB, with as much payload as my V10 F250, to tow an 8000lb 5th wheel? Both within their respective specs.
If I had an F150HD with the EB, I wouldn't hesitate do it, as long as I was within all the weight ratings.
S
2008 F250 XLT 4x4 SC LB V10
2010 Outback 321FRL 5th wheel
93Cobra2771
East Tennessee
Posted: 02/24/12 10:56am Link  |  Print  |  Notify Moderator
x2
The HD package adds 500# cargo capacity and the Max Tow adds an additional 500#. No reason a lightweight fiver can't be used.
And a lightweight fiver will exclude lenth vs wheelbase on the EB as well.
Don't get me wrong, if I was a fulltimer, I would want a 3/4 or 1 ton to pull with, simply because of the statistically heavier parts that they come with compared to the 1/2 ton.
But if was (am) a weekend warrior with short trips, and used the truck as a daily driver the rest of the time, the cost of maintenance and the better fuel mileage would (and did) steer me toward a 1/2 ton.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
JPEC
Cambridge, ON
Posted: 02/24/12 02:38pm Link  |  Print  |  Notify Moderator
93Cobra2771 wrote:
x2
You have that first part mixed up, the max tow brings it to 7650/7700# gvwr. The HD payload takes it to 8200# regardless, of other option.
And for the earlier post about Crew cab HD payload, it CAN be done with XLT, just built one with dealer few days ago (XLT, ecoboost CC 4X4, HD payload, max trailer, +other stuff). I know it won't work on Ford web, it DID, but won't anymore. If you use carcostcanada you can build it still.
Jamie & Paula
275BH Dutchmen Sport
2012 F150 XLT, Max Tow, Ecoboost
shum02
Burlington ON CDA
Posted: 02/24/12 06:22pm Link  |  Print  |  Notify Moderator
I got a friend about to put in an order for one this summer. I'll check with him regarding dealer orders. Maybe it's online order issue? Most options and trim levels are the same north and south of the border on all F-Series trucks.
Regarding this truck and an 8000lb gvwr 5er? No issues with me either if the numbers say it can. Seriously nice truck but I've got a soft spot for F150s [emoticon]
Page of 6
