Shirl V
Maryland
I wrapped the pole with the nonskid cabinet liner.
Shirl V
1999 Georgie Boy Maverick 26'
I monitor CB Ch 13
ktmrfs
Portland, Oregon
x2. they are also a little shorter between the hanger and hook so if you have a short closet, it helps give more room between shirts and bottom of closet.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
lots2seeinmyrv
Ocean Springs, MS
Shirl V wrote: I wrapped the pole with the nonskid cabinet liner.
Hey...that's a good idea and I have lots of that stuff!
2010 Tundra TRD 4x4 Dbl Cab 5.7L V8 4.30 Max Tow 10,300 Payload 1,640 Class IV Hitch 1,030
Prodigy P2 - Blue Ox Sway Pro 10K/1K lbs
2012 Evergreen Ever-lite 29FK
lots2seeinmyrv
Ocean Springs, MS
tandkj wrote: Pack enough clothes into closet that would normally fit in three closet's, the tightness of the clothes keeps them from moving. DW's solution.
That's funny! That's probably why the all fall off, trying not to take everything I own and stuff it in there LOL. Always take to much then have to haul it all out of there.
Slowmover
Corpus Christi, Texas
Have the tires and wheels balanced on a HUNTER GSP-9700.
Add CENTRAMATIC wheel balancers.
Have trailer shock absorbers installed.
Align trailer axles. Check individual wheel braking force.
Dial in the hitch rigging on a certified scale.
Worse is happening to your trailer than clothes falling off the rod.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 15-cpm solo, 25-cpm towing
LarryJM
NoVa
'68Monaco440HP wrote: Have the tires and wheels balanced on a HUNTER GSP-9700.
IMO you obviously don't understand the dynamics of a TT towed behind a TV.
None of those items you listed will prevent clothes from coming of the bar in a closet.
Larry
lots2seeinmyrv
Ocean Springs, MS
crrroger wrote: A cheaper form of LarryJM's idea.
I use a length of 3/4" PVC pipe laid on top of the hangers and bungied to the main rod with a couple of loop type tarp bungies.
I have a spring rod that fits across so I'm going to try that with the bungee around both the spring rod and the main rod and see how the next trip goes.
Thanks everyone for all your help, much appreciated!
crrroger
Spring Creek, Nevada/Rainbow Acres, Arizona
2005 Triple E Regency Class C with a 1990 Daihatsu Rocky toad.
Slowmover
LarryJM wrote: '68Monaco440HP wrote: Have the tires and wheels balanced on a HUNTER GSP-9700.
Larry
Really? Once I finished the above work on mine (as applicable) I never had hanging clothes come off of the closet rods again. And trashed the foam and other materials the PO had installed on them. Same for cabinet doors and the rest.
What was it I "misunderstood"?
tomman58
Southeast Michigan
This getting a little goofy. One person is talking keeping hangers on the rod(which is a varible anyways as mine are 4 foot long and several are only 2 foot).
the other SA person is talking "Clothes falling down". Get it?
Also if I had to do all the stuff that one poster said to keep my rig towing properly I would be look'n at another rig. But then I only tow 12 to 15 thousand miles a year LOL
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
