smkettner
Fill to 60psi cold and you are good to go.
Cold is in the morning before the sun hits them.
675 watts solar
Coyotecprs
chicago
Weigh the rig to determine the load on the tires adjust pressure accordingly. You should not need to have over 60 PSI probably less.
2005 Dodge Ram 2500, 5.7 Hemi
2007 Jayco Jay Flight 30.5 BHS
mitch5252
NW Tennessee
OP here...
I thought that both under- and over- inflated were bad things in the tire world?
2008 Fun Finder X-160
2006 Toyota Sienna Limited
Equal-i-zer Hitch
Prodigy Brake Controller
Supreme Oppressor
Grande Prairie, Alberta
Under-inflated for the load they carry is bad. Find a load inflation table for your size tire at 60 psi and see if the weight listed is enough. If not, upgrade whatever components necessary.
2006 F350 6.0 diesel cc lb srw
2004 Jayco Jayflight 30.5BHS
JIMNLIN
out here
The advantage of a higher load range tire comes at those higher pressures. Its been my experience sticking with a tire that has the same pressure rating as my trailers wheels works best in the long run.
If your trailer came with load range C tires (50 psi). I would stick with a load range C tire if you have the single axle trailer. That way you can run them at max pressures for a cooler operating/longer lasting tire.
Some aluminum wheel max pressures are dictated by the valve stem. The low pressure rubber valve stems are rated at 60 psi max. Install the high pressure rubber stems with the brass centers (OEM on our 2500/3500 trucks). Their rated up to 100 psi.
Now if your wheels are stamped 60 psi max then 60 psi is all I would put in them.
'97 Park Avanue 28' 5er 11200 gvwr two slides
SoCalDesertRider
SanDiego, CA, USA
I would run the tire at 60 psi, so as not to exceed the pressure rating of the wheel.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
smkettner
mitch5252 wrote: OP here...
If you had a 50 psi tire and replaced with a 65 psi tire of same size then it has the same load rating at 50 psi. More load rating at 55, 60 and max rating at 65 psi. You don't need the max rating. 60psi keeps you well over the actual load rating of the previous tire at 50 psi.
jerem0621
Sequatchie, TN
smkettner wrote: mitch5252 wrote: OP here...
X2, Look at the load rating on the Tire. That is the load the tire is designed to carry at max PSI.
Your tires will be just as rigid at a lower PSI with an equally LOWER load on them.
Thanks!
Jerem
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Chuck&Gail
In the Colorado Mountains
Would I personally overload my rims by 8.33% ON PURPOSE? NOPE! Do I think it is safe, NOPE. Would I purposely overload my tires? Nope. I prefer safety margins, not overloading.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
gmw photos
midwest
I use the same rims as the OP and I too am going to install LR D tires on these rims. I checked with the RV manufacturer, told them what I was wanting to do, and he said he would check with their wheel supplier. He called me back this morning and said the wheel supplier gave the okay to inflate these wheels to 65 psi cold with load range D tires.
The weight limit of 1900 pounds per wheel should still be observed.
So my plan is to use LR D tires, inflated to 65 psi. This will increase the load capacity from 1760 ( LR C at 50 psi ) to 1900 ( wheel capacity limit, tire capacity would be 2094 at 65 psi, but we're limited to 1900 ).
The higher pressure tire should also run cooler due to less flex.
I will also use metal valve stems.
My plan is to use either Hankook RA08 or Kumho 857. I'm leaning toward the Hankook.
