RV.Net Open Roads Forum: General RVing Issues: Watering Batteries
 > Watering Batteries
Big Katuna
Deland, FL
Posted: 02/22/12 07:42pm Link  |  Print  |  Notify Moderator
Dave H M wrote:
gees I haven't had to add water tomy batt in three years. [emoticon]
Many of us leave the RV plugged in. I need to add water monthly. I could do it bi-monthly, but if I miss a cycle, then my batteries could suffer. The plates never get dry when I fill monthly.
Before I bought the Pro-Fill, I would often procrastinate, because it took time, bending over, sticking my head into the battery area.
Now, its; stick a hose into a gallon jug, squeezing the bulb 2-3 times, put it away. I'll take the system with me when I sell the RV.
My Kharma ran over my Dogma.
Irover
Where ever the Good Lord Wills
Posted: 02/22/12 08:24pm Link  |  Print  |  Notify Moderator
If you look down into the deep cycle battery cell hole you can see the bottom edge, as long as the water is not above it; and covering the plates you are fine. As the battery charges this prevents the gassing from spilling the acid all ovet the compartment causing corrosion. Keeping the batteries case clean also helps the life of the battery and don't forget the terminals connections. Well kept batteries I have seen can last up to 6+ years. Irover
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 02/23/12 06:28am Link  |  Print  |  Notify Moderator
7.3 psdman wrote:
You might want to check to see how much water you need in the battery. You can flood some batteries by adding too much water and it really reduces the ability of them to hold a charge. After I flooded a new interstate deep cycle I found out the water level was supposed to be just about a half inch over the plates. Not up to the bottom of the holes.
Yup, the water should not be touching the bottom of the holes otherwise you will get gasing as Irover stated. I plug in my two Interstate 6-volts in May and disonnect them in November and I have always been fine with the water level above the plates. I top the water off in November and put them on charge for a few hours.
Eric
2014 Enterra 314RES (Cruiser RV) TT, Equal-i-zer 12K, Honda 2000 Genny
2014 Ram 1500 Quad Short Bed, 5.7L Hemi, 8 speed auto, 4x4, Line-X
FQCC/Camping Quebec, KOA, Good Sam
© 2016 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
