RV.Net Open Roads Forum: Class A Motorhomes: Norcold 1200 HE AC
 > Norcold 1200 HE AC
JohnnyT
Goshen New York
Posted: 02/20/12 05:54pm Link  |  Print  |  Notify Moderator
Interesting Problem... My Norcold 1200 is flashing and beeping a failure... An AC HE which is indicating a problem with the electrical heating elements.
A measure of the resistance at room temperature of both elements finds that they are within tolerance.
All connections appear to be in order.
The refrigerator is maintaining temperature. Both elements are producing heat...
Other than the beeping and error code flashing I would not know there was a problem.
The only variable I know of is to replace the control board... I did pull and inspect the control board no sign of any problem...
Any thoughts?
JohnnyT
hottubkid
SCHAUMBURG,IL
Posted: 02/20/12 06:46pm Link  |  Print  |  Notify Moderator
I would try taking a pencil eraser to the contacts on the control board. To clean them
Any thoughts?
JohnnyT
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
dougrainer
Carrolton, Texas
Posted: 02/20/12 07:21pm Link  |  Print  |  Notify Moderator
HE AC means that one of your heaters has failed by being OPEN. That can happen intermittantly and the Element/s can OHM out correctly. They can fail when running HOT. Thus the intermittant operation. When it happens again, you then clamp on a Amp meter to see which element is open. But, It would be better to just replace both elements at the same time rather than the one that is defective. Doug
Old-Biscuit
Across the USA
Posted: 02/20/12 08:21pm Link  |  Print  |  Notify Moderator
Your getting a reading of 58-68 ohms on each heating element....correct?
Then the problem is at the power board. Check the yellow & brown wire(s) connections to power board.....otherwise may have to replace power board.
LVJ58
Las Vegas, Nevada
Posted: 02/20/12 09:53pm Link  |  Print  |  Notify Moderator
Hi Johnny, hopefully Doug Rainer will catch your post and have an answer for you..
Good luck, Jim
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
JohnnyT
Goshen New York
Posted: 02/21/12 09:43am Link  |  Print  |  Notify Moderator
Thanks all for the responses... The Ohm readings are 64.3 and 66.1.. I have checked the resistance several times...after letting the elements cool and when they were still hot..
Doug, I plan on trying to round up two heating elements since I have everything accessible.
This morning I did take readings with a clamp on amp meter. I expected to see about .2 amps what I got was 1.63 and 1.51.
I also checked the temperature at the bottom of the stack.... 221F. The temperature inside the refrigerator is 34.1... The freezer section is at 14.1F...
JohnnyT
* This post was edited 02/21/12 12:08pm by JohnnyT *
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
dougrainer
Carrolton, Texas
Posted: 02/21/12 10:21am Link  |  Print  |  Notify Moderator
The AMP draw is 1.7 on each element. Doug
JohnnyT
Goshen New York
Posted: 02/21/12 12:12pm Link  |  Print  |  Notify Moderator
Thanks Doug, neither element is drawing that much... One is lower than the other. I wonder what the threshold for the HE AC fault to be triggered?
Johnny
dougrainer
Carrolton, Texas
Posted: 02/21/12 03:17pm Link  |  Print  |  Notify Moderator
Johnny
120 elements either work or they don't. I would bet your line voltage is LOW or your amp meter is not accurate. The threshold is NO current as it senses an OPEN condition. No current flow at all. Doug
