RV.Net Open Roads Forum: Class hitch 2.5" receiver - do I need to change anything?
Search only in Towing
Open Roads Forum  >  Towing
 > Class hitch 2.5" receiver - do I need to change anything?
zackyboy3rs
Eastern North Carolina
Posted: 02/20/12 06:28pm Link  |  Print  |  Notify Moderator
New hd has the class5 receiver with a 2.5 inch opening. I have been using the Equalizer 10k hitch that is 2". I have purchased a reducer that converts from 2.5" to 2".
TT hitch wt is 800lbs and 7500 gvw.
Is there any changes needed? Equalizer 10k still good?
2009 Chevy Silverado LTZ 2500HD 6.0L, 3.73, Gas sipper
2015 Jayco Eagle HT 27.5 RLTS
coug
Eastern Washington
Posted: 02/20/12 07:03pm Link  |  Print  |  Notify Moderator
I had to readjust my Equalizer when I bought my Chevy. The back sat about 3" higher than my old F250. My truck came with the reducer and I have not had any problems with it.
2010 Arctic Fox 22GQ
2011 Chevy 2500HD LTZ
SoCalDesertRider
Arizona desert
Posted: 02/20/12 08:08pm Link  |  Print  |  Notify Moderator
Should be good to go.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
n7bsn
Yes
Posted: 02/20/12 08:13pm Link  |  Print  |  Notify Moderator
Be warned, if your new unit is a Ford, there may be some issues with some of the reducers sold. The problem is the Ford units are slightly different then some third party units.
If you have a Ford and run into this problem, do NOT grind anything off, your options are to exchange it or try taking the paint off. I managed just fine by taking the paint off.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
zackyboy3rs
Posted: 02/20/12 08:15pm Link  |  Print  |  Notify Moderator
Chevy silver ado
christopherglenn
Near Yosemite
Posted: 02/20/12 10:05pm Link  |  Print  |  Notify Moderator
Other then the loaded hitch height, nothing is different. The rear squat (rear spring rate) is likely different, so teh loaded height is all that matters. Adjust the hitch so the front end is at the same height - or slightly lower then unloaded.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
APT
SE Michigan
Posted: 02/21/12 06:15am Link  |  Print  |  Notify Moderator
You are fine as long as the reducer is rating for the weight. Enjoy the new truck!
2017 Subaru Outback 3.6R
dmax_83
SE WIsconsin
Posted: 02/21/12 03:26pm Link  |  Print  |  Notify Moderator
The owners manual for my '11 does not mention anything about the capacities being reduced when using the reducer. You should be just fine, just don't forget to take it out when you take your hitch out of the receiver. I have almost forgot on several occasions.
1998 Jayco Eagle 302FK (Honda EU3000is)
2016 GMC Sierra Denali 3500HD 4x4 Duramax/Allison
2003 Honda Aquatrax F-12X Turbo
mikefos
Fredericksburg, TX
Posted: 02/23/12 12:58pm Link  |  Print  |  Notify Moderator
All I had to do was adjust the hitch head height a bit as the 2500HD sits higher than our previous tow vehicle (4Runner), and add a spacer washer as the truck is much longer wheelbase. The only thing I didn't care for, but it still worked fine, was how sloppy the reducer sits in the hitch receiver. My new heavier Equal-i-zer for my soon to arrive heavier trailer will have a 2 1/2" shank to fit better in the receiver, as I had to order a special size shank anyway.
Mike and Kim
2012 Jayco Eagle Super Lite 308RETS, TST 507 TPMS
2010 Chevy 2500HD, Duramax/Allison, 2WD, Long Bed, Crew Cab, Duraflaps, AMP Bedstep
Equal-i-zer 1400/14K Hitch
taken
Western MA
Posted: 02/25/12 09:47am Link  |  Print  |  Notify Moderator
The reducers can be a pain when sliding the hitch in as now you have to line up two sets of holes for your pin. If you aren't ever going to use a 2.5 hitch, you can just tack weld the reducer sleeve in place. I added a 2.5 Reese Titan to my 09 F250 as my Arctic Fox had a Reese Dual Cam setup with a 2.5 hitch. When I sold it for our last trailer, I went to an Equalizer as they are MUCH easier to set up and hook up. It only had a 2" hitch so I tacked the sleeve in place. All was fine in 2500 miles last year...
Regards, Rodney
TV - 2017 F350 SRW CC SB 4X4 6.7
TH - 2015 FR XLR 395AMP
