RV.Net Open Roads Forum: Towing: 3.73 vs 4.10
Search only in Towing
Open Roads Forum  >  Towing
 > 3.73 vs 4.10
zackyboy3rs
Eastern North Carolina
Posted: 02/20/12 06:43pm Link  |  Print  |  Notify Moderator
My new (used) tv has the 6.0l and the 3.73 gears. I am not an expert at all so please share with me the do's and dont's. Always use the tow/haul button? Tow in the "d" gear?
Anything else I need to consider?
I mainly do flat road towing. Will be traveling to NC mountains.
Any advantages or disadvantages of the 3.73?
* This post was edited 02/20/12 06:52pm by zackyboy3rs *
2009 Chevy Silverado LTZ 2500HD 6.0L, 3.73, Gas sipper
2015 Jayco Eagle HT 27.5 RLTS
hmknightnc
Wilmington, NC
Posted: 02/20/12 06:50pm Link  |  Print  |  Notify Moderator
With your trailer put it in tow/haul and go. If hunting gears pulling mountains go to manual and select lower gear.
skipnchar
Topeka or somewhere else
I'd put it in drive and go. If you have a transmission heating problem climbing mountains, use tow haul. If you want slightly better fuel economy leave it turned off. It (tow/haul)can also be handy for descending mountains if you don't want to down shift the tranny manually. Good luck / Skip
zackyboy3rs
Posted: 02/20/12 06:57pm Link  |  Print  |  Notify Moderator
Will it hurt the trans if I do not use the tow/haul button?
sandpiper1
Kansas
Posted: 02/20/12 07:50pm Link  |  Print  |  Notify Moderator
I've always used the tow haul mode in my Fords. After over 265,000 combined miles I've had no problems. The 3.73 should be ok for what you are doing. Mine has a 4.10 and has no problems with any grade.
2014 F350 DRW 6.7L PSD Crew Cab Lariat LWB FX4, B&W with factory prep, 2012 Montana Mountaineer 346LBQ
MARKW8
Akron OH
Posted: 02/20/12 08:01pm Link  |  Print  |  Notify Moderator
Use the tow/haul, if it won't hold OD going down the road, use 3rd. You might end up in 3rd a lot with any hills. One question, do you have the 4spd or 6speed tranny? The 6spd has much better towing gears.
Mark
zackyboy3rs
Posted: 02/20/12 08:05pm Link  |  Print  |  Notify Moderator
6 speed and has towing package.
Bob/Olallawa
Kitsap Co, WA
Posted: 02/20/12 08:59pm Link  |  Print  |  Notify Moderator
The book says to use the tow haul when heavy loads or towing so why not use it. 373's with the 6 speed should be fine. Yes that gas engine likes to rev, turn it loose and it will do the job for you.
Welcome to my home, that door you just broke down was there for your protection not mine.
Seamutt
Prince George BC Canada
Posted: 02/20/12 09:41pm Link  |  Print  |  Notify Moderator
Get a scan gauge so you can see your fuel consumption real time and co-ordinate the tow-haul with it. After you experiment with the two knowledge of using the tow-haul will develop. I use the tow-haul up steeper hills and downhill if needed to help control the speed using less braking. I also use tow-haul going downhill empty so I don't have to use my brakes as much.
APT
SE Michigan
Posted: 02/21/12 06:07am Link  |  Print  |  Notify Moderator
I recommend using tow/haul mode and M5, manual mode 5th gear max. I doubt the truck can hold 6th gear. Consult your owners manual on the uses and benefits of each. If you do not have a paper copy, you can download a PDF from the Chevy web site. I find them easier to read and search anyway.
You can expect a lot of time in 4th and 5th gears on the highway. While the 4.10 axle ratio is rated for quite a bit higher tow rating, I think the 3.73 is artificially lower than it needs to be from a performance perspective. People are happily towing 10k pounds with that combination. While my 6.0L is fine from 1500rpm+, it really wakes up over 3500rpm. Enjoy the new truck!
2017 Subaru Outback 3.6R
 > 3.73 vs 4.10
