RV.Net Open Roads Forum: Beginning RVing: Water Regulators
 > Water Regulators
Page of 5
DRM796
Eastern Shore of MD
Posted: 02/20/12 07:48pm Link  |  Print  |  Notify Moderator
New to this and was wondering if a water pressure regulator is necessary? If so how do you choose one?
Thanks
2012 Wildcat 313RE
2004 Chevy 2500hd crewcab long bed Duramax/Allison
Old-Biscuit
Across the USA
Posted: 02/20/12 07:59pm Link  |  Print  |  Notify Moderator
We FT so we are always using water from different sources.....seen pressure at only 30# and have seen 110#. Have been where pressure was OK (45-50#) and then surge to over 100#.
We purchased a Watts Adjustable Regulator (which can be rebuilt) after trying the inexpensive in-line so called regulators that are sold at CW/Walmart.
We always use it......set at 50#.....if water source pressure is lower than regulator opens fully........if pressure is higher it controls at 50#.
travel4family
Ohio
Posted: 02/20/12 08:02pm Link  |  Print  |  Notify Moderator
Can I tag on? I have wondered about the regulator, and a few people have said get a filter. Can that be a "package deal" or do they have to be two separate things? (I keep picturing all this stuff attached to the hose!)
dqdick
Council Grove, KS
Posted: 02/20/12 09:19pm Link  |  Print  |  Notify Moderator
We have a regulator and then two filters after a small bit of hose then on to the rig. Got our equipment from the RV waterfilter store via the net, but you can get similar items at Lowe's or about any home improvement or many RV parts stores. Last place we stayed in Las Cruces, NM had a big sign at the desk warning that their in park water pressure was 120#, not something you want in your rig.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
PhilR.
Central Texas
Posted: 02/20/12 09:21pm Link  |  Print  |  Notify Moderator
Could you state which model you use?
thanks,
PhilR.
Sandia Man
Rio Rancho, NM
Posted: 02/20/12 09:28pm Link  |  Print  |  Notify Moderator
Water pressure can vary dramatically so getting a water pressure regulator is paramount to prevent damage to your water lines. There are basic models that deliver about 40psi, some models delivers a bit higher pressure of about 55psi, and higher end models that are adjustable.
Bumpyroad
Virginia
Posted: 02/21/12 04:10am Link  |  Print  |  Notify Moderator
Thanks
necessary YES.
buy a good watts one, not an elcheapo.
bumpy
Old-Biscuit
Across the USA
Posted: 02/20/12 09:48pm Link  |  Print  |  Notify Moderator
thanks,
PhilR.
Watts model 263A w/gauge
Almost bought the H560 w/gauge.....it was smaller
but the flow rate was only 2-2.5 gpm
The 263A flow rate is 4-4.5 gpm and I didn't want to restrict flow just control pressure.
Bought it at a plumbing supply warehouse.
You can order on-line......I like this place for water stuff
RV Water Filter Store
old guy
Oregon (pronounced Or e gun)
Posted: 02/20/12 10:03pm Link  |  Print  |  Notify Moderator
I would say yes, reason? I came out of our TT one morning and found the white water hose looking like a large snake who just ate the dog.
ScottG
Bothell Wa.
Camco makes a HIGH volume fixed regulator that flows perfectly for RV's and is only about $9. Make sure you get the high volume model and not the standard part.
Scott, Grace and Wesly
H0NDA eu2000i
Page of 5
 > Water Regulators
