RV.Net Open Roads Forum: Tech Issues: Dometic
 > Dometic
spro2395
Hudson Fl
Posted: 02/21/12 05:31am Link  |  Print  |  Notify Moderator
Hi All
The Dometic refrigerator in our 5th wheel is acting up. When we have it on electric it's nice and cold but when we need to travel and it switches to gas it gets warm. The burner lights ok but it's like the flame is not hot enough to make the chemical reaction.
01 Dodge QC 1500 Shasta 256
dougrainer
Carrolton, Texas
Posted: 02/21/12 06:30am Link  |  Print  |  Notify Moderator
1. Clean the burner
2. Verify CORRECT LP pressure at the refer (11.5 inches w/c) Doug
pkunk
Questa, NM
Posted: 02/21/12 09:30am Link  |  Print  |  Notify Moderator
spro2395 wrote:
Hi All
You need to clean the burner orfice. Flame should be larger. See[image]
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
spro2395
Hudson Fl
Posted: 02/21/12 12:11pm Link  |  Print  |  Notify Moderator
How do you check the LP pressure?
Old-Biscuit
Verde Valley
Posted: 02/21/12 12:24pm Link  |  Print  |  Notify Moderator
With a U-Tube Manometer (or a dial-type manometer that has been calibrated).
Short of having a manometer......pay a tech.
I'd clean burner & orifice first. If other gas appliances are working then LP pressure is OK
JC2
Mo/Texas
Posted: 02/21/12 12:28pm Link  |  Print  |  Notify Moderator
http://www.rverscorner.com/manometer.html
This link will explain what it is and how to make one. I would try what oldbiscuit suggested first.[emoticon]
2004 Newmar DSDP 4015,Cummins ISL 370hp,Spartan MM Chassis,2013 Chev Equinox AWD Towed,Ready Brute Elite TowBar/Brake,FMCA #402879,SKP#120487
pkunk
Questa, NM
Posted: 02/21/12 05:11pm Link  |  Print  |  Notify Moderator
It is most likely a dirty orfice.
spro2395
Hudson Fl
Posted: 02/21/12 05:29pm Link  |  Print  |  Notify Moderator
Some of the reading I
've done suggest using an air compressor
to blow out the burner area to remove rust and soot from the flue. Does this sound like a good place to start? The gas stove and oven worked fine last week when we camped at FDR in Georgia!
pkunk
Questa, NM
Posted: 02/22/12 11:24am Link  |  Print  |  Notify Moderator
You need to remove the orifice, soak it in acetone, and blow it out gently in reverse direction of gas flow. It is a ruby with a very small hole-do not try to stick anything through it
 > Dometic
