RV.Net Open Roads Forum: Technology Corner: How To Change Hard Drive Partition Size
 > How To Change Hard Drive Partition Size
Page of 5
vwsportbug
Ontario, Canada
Posted: 02/21/12 09:28am Link  |  Print  |  Notify Moderator
My "C" drive is up to 96% filled up but I still have over 65 Gb free on my "D" drive. Is there a way to change the disk partition to take space from D and add it onto C instead?
I'm pretty much computer illiterate so would need some pretty detailed directions if this can be done. Can anyone help?
VeeDub
2006 Carriage Cameo LXI F35FD3
2006 Ford F350 Dually
Helmsey
Knoxville, TN
Posted: 02/21/12 09:39am Link  |  Print  |  Notify Moderator
What version of Windows are you using?
A quicker (easier) fix might be to move your page file from the C drive to the D drive. Depending on how much memory you have installed on your computer that can clear up a gig or two of space.
If you wanted to do that, directions for Windows XP can be found here: Clicky
KK4PFX
2010 Chaparral 322RLTS
2004 Chevrolet 2500HD D/A CCSB 4x4
Days camped in 2011: 22
Days camped in 2012: 34
Days camped in 2013: 6
bdpreece
Woodburn Oregon
Posted: 02/21/12 10:22am Link  |  Print  |  Notify Moderator
You can download a free copy of Partition Magic at Partition Magic download. When I worked for the federal government we used the paid version and it worked well.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2008 Ford Explorer toad
cleo43
Montreal
Posted: 02/21/12 10:24am Link  |  Print  |  Notify Moderator
Go to Menu System Restore, remove most of the Restore Points, except one or two latest.
MitchF150
Washington, the State
Posted: 02/21/12 10:25am Link  |  Print  |  Notify Moderator
I don't think you can do it and not have to reformat the entire drive.. Meaning, you will have to backup your data and re-install everything once it's done..
Not usually the job to be undertaken if you have not done it before.
I think there are programs out there that say they can repartition without formatting, but I've never used one, so no personal experience. Anytime I've needed to repartition, I used the old DOS command "FDISK" and started over.. Now, I simply partition for a single C: drive from the start..
Might check out the "Geeks" at Best Buy or Office Depot and say see what they charge to do that..
Going along the lines of what Helmsey said, moving the PAGE FILE will usually net you some free space.
So will going thru and cleaning up the drive. Depending on the OS, you can run the included "Disk Cleanup" wizard to free up some space.
Big space hogs can be the "TEMP" folders you see under Windows. You might check you Internet Options to see how much space you are reserving for Temporary Internet Files.
If you have a bunch of files in your "My Documents" folder, you can always move them over the the D: drive. Sure, you'll have to go there to get to them, but you can create a shortcut.
You do want to be careful when deleting or moving files, unless you know for sure they are not 'system' files...
Good luck!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
MrWizard
Traveling
Posted: 02/21/12 11:04am Link  |  Print  |  Notify Moderator
partition magic will do the job
first step tell it to shrink 'D' 20gb
second step is to increase 'C' 20gb
But I have to agree it would be safer to just remove some restore points and other not needed temp data
If you have filled the drive with lots of pictures or video or work files
I would recommend buying and external drive and copying all those files to the external drive
and then deleting as much as possible from drive C
this gives you a safe backup I case of computer failure and makes room on the 'C' pwrtition with out doing a repartition operation
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Kiwi_too
Western, WA
Posted: 02/21/12 11:18am Link  |  Print  |  Notify Moderator
There might not be a need to reallocate space on the drives. Can you move the contents of "My Documents" to D drive. This puts your data and programs on a separate drive, making a backup and restore of your primary drive smaller and quicker.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
Dutch_12078
Great Sacandaga Lake, NY
Posted: 02/21/12 11:30am Link  |  Print  |  Notify Moderator
Partition Magic or GParted will do the job, but I suggest defragging both drives first for the best results.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
mlts22
Austin, Texas
Posted: 02/21/12 12:10pm Link  |  Print  |  Notify Moderator
Windows Vista and Windows 7 allow you to shrink and grow partitions without needing third party software. Windows XP won't.
RoyF
Fayetteville Arkansas
Posted: 02/21/12 01:05pm Link  |  Print  |  Notify Moderator
A 500 gig external drive doesn't cost much. Could you move some files to an external drive to free up space on your internal drive?
Page of 5
