RV.Net Open Roads Forum: Class A Motorhomes: New Garmin...Help!
 > New Garmin...Help!
goufgators
Crawfordville, Florida
Posted: 02/21/12 11:00am Link  |  Print  |  Notify Moderator
Recently, I bought a Garmin 2595 and when programming routes, the unit almost always routes directly through a city. In most cases, I prefer to take the 'truck route' around the city but cannot figure out how to make the unit accept the route I want. My older Garmin Street Pilot 2620 was easy to make such route adjustments. But not this new one! There must be a way to force this 2595 to accept the route I want but after reading the Manual several times, I can't figure out how to do it. Any advise, help, assistance will be appreciated.
Thanks,
Larry
2005 Winnebago Itasca (Ford)
2005 Honda CRV Toad
Invisi-brake
donn0128
Pronounced Ore-gun
Posted: 02/21/12 11:09am Link  |  Print  |  Notify Moderator
Setup/preferences should get you to where you need to make the settings change.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
cpmath
New York
Posted: 02/21/12 11:14am Link  |  Print  |  Notify Moderator
Contact Garmin support, that's what they are there for.
huffmeister
Travelling
Posted: 02/21/12 12:48pm Link  |  Print  |  Notify Moderator
What are you using to program the route? You should have gotten a copy of Garnin's "MapSource" which works quite well also.
I would recommend you get MS S&T (or another mapping program) and do the routing in that. Then you can set waypoints to force a route.
Very easy to do that way.
RicJones
So. Cal.
Posted: 02/21/12 01:29pm Link  |  Print  |  Notify Moderator
You should be able to add waypoints to force the new route. You might try something like adding a waypoint that's an intersection like the highway you want to take and one of it's off ramps.
vermilye
Oswego, NY, USA
Posted: 02/21/12 01:47pm Link  |  Print  |  Notify Moderator
Also check that you don't have it set on "shortest route." The shortest rather than the fastest route can sometimes get interesting...
As huffmeister noted, using Mapsource on your computer to plan your route then transferring it to the GPS usually works. In Mapsource you can change the route by dragging a it to the roads you wish to travel. As long as your GPS doesn't recalculate the route when you transfer it, that's the best way to force it on the route of your choice.
Jon Vermilye My Travel Blog
My Photo & RV link blog
bluwtr49
Green Valley, AZ
Posted: 02/21/12 02:22pm Link  |  Print  |  Notify Moderator
An easy way to do it is simply get on the truck route and let the GPS catch up with you. Simple and effective.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
bobfinch
Ma
Posted: 02/21/12 02:57pm Link  |  Print  |  Notify Moderator
I used Mapsource last year and once I loaded it to the new gps it recalculated it. I haven't gotten any deeper into the new GPS but man I miss my streetpilot it was a non-issue?
vermilye
Oswego, NY, USA
Posted: 02/21/12 05:05pm Link  |  Print  |  Notify Moderator
Yea, some models of Garmin's GPSs insist on recalculating each time you load a route from Mapsource to them. My 855 had that problem...
NC-Hawk
South
Posted: 02/21/12 06:33pm Link  |  Print  |  Notify Moderator
Forum for Garmin Nuvi's
Great forum and informative monitors. [emoticon]
