RV.Net Open Roads Forum: would like to install hardwood floors in my tt
 > would like to install hardwood floors in my tt
chopper5670
kentucky
Posted: 02/21/12 01:53pm Link  |  Print  |  Notify Moderator
just finished installing hard wood floors in my home and thought maybe installing in my tt..its a 2006 fleetwood mallard. any ideas on pros and cons on this
chopper5670
kentucky
Posted: 02/21/12 02:03pm Link  |  Print  |  Notify Moderator
oops .....just figured out why i cant add hardwood floors......slide out would not be able to retract
PCronin68
RI
Posted: 02/21/12 02:09pm Link  |  Print  |  Notify Moderator
my friend used the laminant/pergo and it worked fine. He had to take out the couch and whatever else to do entire RV
2010 Passport 2910BHS w/ 2007 Yukon XL Denali
Mighty Ming
Carlsbad
Posted: 02/21/12 02:53pm Link  |  Print  |  Notify Moderator
If you do so....keep in mind the added weight ..that stuff is not light. Looks nice though.
skipnchar
Topeka or somewhere else
Posted: 02/21/12 03:30pm Link  |  Print  |  Notify Moderator
Just make sure your trailer has enough CCC to carry the extra weight.
Good luck / Skip
NanciL
Bakersville, NC, USA
Posted: 02/21/12 04:53pm Link  |  Print  |  Notify Moderator
Too much weight. -I wouldn't do it
Jack L
Jack & Nanci
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 02/21/12 04:56pm Link  |  Print  |  Notify Moderator
If you want the look of wood, and want to ensure your slide will still work, why not go with something like this. I'm sure you can get it at any home improvement store.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
Kanyonkitty
Gerrardstown, WV
Posted: 02/21/12 06:30pm Link  |  Print  |  Notify Moderator
When the time comes that our 5'er needs the carpet replaced, we will do it with vinyl sheet goods with either a wood floor look or ceramic tile look. The laminate will add unwanted weight and the Allure is not recommended for use in the RV due to the temperature changes.
Deep wedgewood blue '99 7.3L PSD F-350 Super Duty crew cab long bed dually or wedgewood blue '97 F-350 7.3L PSD crew cab longbed SRW, Member: Sunlineclub.com Rescue a retired Greyhound, greyt calm low maintenance traveling companions
wbwood
Mooresville/Troutman, NC area
Posted: 02/21/12 09:56pm Link  |  Print  |  Notify Moderator
My brother in law added wood or laminate flooring to his Wanderlodge bus. But he does not have any slide outs. Looks good also. But I'm with the others. For the TT, I would do vinyl look a like. They have the peel and stick planks...
Brian
RVing Illustrated
2010 Keystone Sprinter Select 31BH
2001 Coleman Santa Fe
TenOC
On the road -- Full time
Posted: 02/22/12 05:17am Link  |  Print  |  Notify Moderator
I installed an "engineered" wood floor in my TT. Love it. . The floor is only 10mm (?) thick about the same thickness as the old carpet and does not weigh too much. Glued it down -- added a few small brad type nails to each strip.
I have two slides, Before installing the floor, I check to make sure that the slide would clear the floor when it was inside. I was able to adjust my slide up about 1/4 inch. The slide does rub the floor at one spot.
The main advantage of a wood floor is that it is VERY simple to clean. With all the dirt tracked into the trailer (along with road dust from some roads) a simple sweep with a broom get ALL the dirt out. No like having dirt in the carpet the the vacuum will not get out.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
