RV.Net Open Roads Forum: Fifth-Wheels: ??? Tire presure and rim rating
 > ??? Tire presure and rim rating
Our Place
Southwest Ohio
Posted: 02/21/12 02:06pm Link  |  Print  |  Notify Moderator
This has most likely been beat to death here but... I discovered that the rims on my new camper are only rated to 60psi but the tire pressure decal applied by Coachman states tire pressure to be 65psi. Don't the rim max trump the tire rating? Like I can't run 80 psi in the tires if the rim only rates to 60psi.
2001 GMC 2500HD 4x4 with 8.1 gas Allison trans
2011 Coachman Chaparral 268RLE "Campy"
troll3193
SouthWest, MI USA
Posted: 02/21/12 02:15pm Link  |  Print  |  Notify Moderator
the answer is probably yes .... I am in the same boat though as I have e-rated ST tires on 15" rims...
I have run them for 4+ years at 80 PSI and they have worked great...
I am not sure how much I am tempting fate though...
My next move will be to 16" rims with LT tires..
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
donn0128
Pronounced Ore-gun
Posted: 02/21/12 02:28pm Link  |  Print  |  Notify Moderator
Yup. The rims are the limiting factor in your case. Since the rims are probably 15 inch and that means you are likely stuck with ST tires now might be a good time to upgrade to a LT tire and 16 inch rims.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Our Place
Southwest Ohio
Posted: 02/21/12 03:03pm Link  |  Print  |  Notify Moderator
I have already been looking for new rims and tires. If I pull the 15's off soon I can resell them in my shop for boat trailers. Then have a really nice set of 15 inch aluminum camper rims for sale!
skipnchar
Topeka or somewhere else
Posted: 02/21/12 03:24pm Link  |  Print  |  Notify Moderator
If your wheels are the ones that were provided for your trailer when new, I'd be in contact with Coachmen about the problem and see if you can't get a new set of wheels from them. Since THEY recommend the tire pressure and didn't provide you with wheels that can handle that pressure they OWE you the correct wheels for your trailer.
Good luck / Skip
bpounds
Whittier CA
Posted: 02/21/12 04:45pm Link  |  Print  |  Notify Moderator
I wouldn't lose a moments sleep over exceeding rim pressure. Rims don't blow up just because someone puts too much pressure in them. Your concern should be with carrying capacity of those wheels. Just because you go to an 80psi tire, and run them at 80psi, does NOT mean that you can load the trailer to a weight that exceeds the rim rating. The wheels should have a weight rating stamped on them. THAT is what you want to stay below.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Old-Biscuit
Across the USA
Posted: 02/21/12 07:14pm Link  |  Print  |  Notify Moderator
2011 rig with non matched rated tires & rims........Dealer time.
Have them correct it OR put in writing with MFG. co-signed that rim rating doesn't matter and OK to exceed the stamp rating.
JIMNLIN
out here
Posted: 02/21/12 07:20pm Link  |  Print  |  Notify Moderator
Quality made in the USA wheels are load and pressure rated according to folks at southwestwheel. I know my implement trailer dealer sells tires and trailer wheels to the public and will not accept a wheel shipment that doesn't have a pressure rating and load capacity due to liability issues.
Exceeding the rims pressure can result in a split wheel usually when load approach the higher end. Over pressuring a tire or wheel isn't a wise move. And yes I've split more than one truck and trailer wheels when I was younger and mounted 10 ply tires on truck/trailer wheels with a 60 psi rating so I could carry more weight.
Tire and wheel manufacturers warn not to exceed pressure ratings.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Gale Hawkins
Murray, KY
Posted: 02/21/12 10:23pm Link  |  Print  |  Notify Moderator
If I was a dealer I would not sell rims rated under PSI of tires installed either.
With that be said if a rim stamped 60 PSI is going to fail at 80 PSI I do not want to run it at even 40 PSI.
The trend that I see over the years is they tend to stamp the rim with a number that matches the tire max PSI expected to be used with that rim.
Long term liability is reduced by doing this.
Mile High
Denver, CO
Posted: 02/21/12 11:28pm Link  |  Print  |  Notify Moderator
That's crazy advise. You don't run anything over its rated pressure or load. Just asking for trouble and nobody will stand behind you when it happens.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
