RV.Net Open Roads Forum: which chevy trans is better or reliable THM400 or 4L80E
Search only in Tow Vehicles
 > which chevy trans is better or reliable THM400 or 4L80E
blt2ski
Kirkland, Wa
Posted: 02/22/12 08:16am Link  |  Print  |  Notify Moderator
I'd build a 700r4 up. Lower first and 2nd gear, ie 3.1 vs 2.48. It has an OD as the 4l80 has. That was my choice back when I had an 88 ext cab, after going thru 2 or 3 th400' in 100K miles of towing. 2nd gear would not hold in a manual position. Never rebuilt it again, finally sold it. Another rig, an 89 R3500, used to go thru TH 400's like clockwork every 40K miles, even with 7-8K mile tranny fluid changes. The later 4l80e trannys seem to be better and longer lasting than the TH400 in my experience. The 700r4 as mentioned before re the th400, it is all manual and you do not need the stand alone computer.
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
Trail-Mate
Frederick, MD
Posted: 02/22/12 09:37am Link  |  Print  |  Notify Moderator
I to would go with a built 700r4. I put a Bowtie Overdrives stage 3 in my 91 Suburban. with manual torque converter lockup. Worked great. The lockup will keep the heat down when towing. Had a 4l80 in mt 93 K2500 never had an issue with it and it still in use. But I found no way to lock up the TC. So it would unlock at every rise in the roads at highway speed towing. This made it hard to keep cool. Computers to run 4l80 are pricey.
1997 Ford F250 Extended Cab, 7.3 Diesel, 8 foot bed.
Reese 16K Hitch
(Moved into Shed) Hensley Arrow
Jordan Brake Controller, Hensley TruControl Gold Shelved.
Open Range 5th Wheel, Roamer RF392 BHS
Happy Camping !!
Nomadac
Columbus, IN
Posted: 02/22/12 03:29pm Link  |  Print  |  Notify Moderator
Deleted
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
john&bet
North Vernon,in.
Posted: 02/22/12 09:53am Link  |  Print  |  Notify Moderator
The company I retired from bought a '97 2500 express van for me to use. It went thru 2 4L80E's at 49k each. All it had to do was pull itself. Personally I did not like it. JMHO.
2004.5 Dodge 2500ctd Quadcab. Lariamie, 3.73, auto. pure stock
2005 Montana 2955 5er
Nomadac
Columbus, IN
Posted: 02/22/12 10:23am Link  |  Print  |  Notify Moderator
I had a 83 GMC Suburban C 2500 w/454 Turbo 400 3.75 ratio (80K miles when we sold it) towing our 89 Avion 7600# and never had any problems. We bought a 2001 Chevy Suburban C 2500 8.1L w/ 4L80 trans. 4:10 ratio and have 48K mileage towing the same trailer and no problems. The original owner towed a horse trailer for a year before we purchased it from and had no problems. The OD with the 4L80 is so much better, more power and better economy when in OD.
I would choose the 4L80 over the Turbo 400 which is a 3 speed vs. a 4 speed.
* This post was last edited 02/22/12 03:33pm by Nomadac *   View edit history
BenK
SF BayArea
Posted: 02/22/12 01:06pm Link  |  Print  |  Notify Moderator
Ditto rebuild what you have.
Install a manual TC lockup
Consider a drive line after market OD
-Ben Picture of my rig
