wildmanbaker
Kennewick, Washington
Had a friend with a TT, that had this same problem. It would flush out, but same problem would re-occur. The fix was to add 5 gallons of water before going on trips, or camping. 5 gallons is not much in the bottom of the holding tank, but it was enough to prevent a build-up starting under the toilet drop. Material apparently was sticking to the bottom of the holding tank, when it was dry.
You can try ice cubes, but as Sully said, good luck. The GEO Method will work, but it will remove all lube from the dump valves, causing hard operation.
If you have a hard build-up under the drop pipe, try filling the tank 3/4 full and letting it set for a long time. Water is a great solvent. If this does not work, a pressure washer will solve the problem.
Good luck
Wildman
NorCal Dan
Coffeyville, Kansas
One of the better items I've purchased for the coach is a closet auger. Cost is below $20 depending on length required. I bought a 3' version for about $12. It is just long enough to use from the toilet to black tank, mine is not a straight dump from toilet to tank. I've also used it from the dump valves and it is just long enough to reach both gray and black tanks.
'08 Monaco Diplomat SFT pushed by '07 Jeep Wrangler -- USAF Retired --
BlackBirdCD
Washington
Had this happen last summer after a long trip with the family. Dumping the black tank was leaving solids, which backed everything up. Decided use the black tank flush line on my unit to fill it up and drain repeatedly to see if I couldn't clear the solids.
Unfortunately the park only had a limited septic system. After the third full black tank flush in my HUGE class-A I noticed all the sewer caps down the park were overflowing with my junk! Hilarious, especially since everyone was at the beach (they were all tent campers anyway). Once my family got back I shoved them in "WE HAVE TO LEAVE NOW!!!"
(but seriously I informed the park attendant who laughed it off, saying "yeah, I thought you were having trouble. Probably should've warned you about our septic system not being large enough for that kind of action". And I took the time to hose off the offending matter).
After letting it sit for a few months full of water, things broke down well enough to clear. THAT'S when I had my next stupid-RV owner moment - the drain hose slipped off as I opened the foul release valve on the black water tank. No choice but to grab the hose and force it back on before it got worse. That was fun.
New road warrior
2003 Fleetwood Bounder 36D
jetboat4
wausau
We keep a garbage can in our bathroom. This is where tp goes. We don't send any into the tank.
1999 Fleetwood Southwind 35S F-53 V-10 Triton with Banks
Horsedoc
Dixie --- N. Georgia
If the vertical pipe from the toilet into the tank is only 2.5 inches off the bottom of the tank, then it is way too close to the bottom. When the tank fills above the 2.5 inch level then the flushed waste cannot get out of the pipe. It simply sits in the pipe and floats. That is a terrible design. The simple answer is to raise the pipe higher off the bottom of the tank. The answer may be as simple as replacing the pipe with on that only goes into the tank a few inches.
The 2.5 inches mentioned several posts back has nothing to do with a pipe diameter. The original poster was talking about the distance from the bottom of the tank to the end of the down pipe.
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
For toilet paper problems we've used RV Digest in the past with success! Good Luck.
mllk3rd
Pismo Beach, California
OK, so I looked at it a little closer today and it definitely looks like its some type of a 90 that goes into the tank, not a traditional 90 as it's much wider than the size of the pipe, almost like a flat pedestal or shelf like vtbigdog described. Think I'll have to remove the toilet and check it out better. It'll have to wait a few months since I'm having rotator cuff surgery Monday.
Thanks for all the help, I did add Calgon to the tanks with lots of water so maybe that will help.
edited 03/02/12 07:15pm by mllk3rd *
chipndip
Madison, AL, USA
jetboat4 wrote: We keep a garbage can in our bathroom. This is where tp goes. We don't send any into the tank. Do what?
deaop01
Mansfield, Ohio
We use Dawn liquid soap in our tanks. The blue stuff that is unscented. Cologon does work but Dawn I think is better. Never had a problem.
You should add 1/3 bottle of Dawn then fill the tank up almost full. Let it set for a week. Drive it around for a while then dump. The Dawn should soften or break down the pile. Fill and dump a couple of times. Add some Dawn and 10 gallons of water. Do this every time and you should never have any more problems.
If this don't fix your tank then I don't have any other answers. The piping could be a problem but I hope that is not the case.
Good luck
Ron
Betty and Ron
2002 Bounder 31W
8.1 with 5 speed Allison
2 slides
2005 Colorado toad
Jim@HiTek
Gresham, OR, USA
I know it's a long shot in regards to the OPs problem but to any lurkers that might have a similar problem, there have been known cases where the wood cutout for the toilet was dropped into the tank during manufacturing. It can float around for years and then end up lodging in a place that plugs either the toilet or the outlet. Since it can float, after it's dislodged, it can come back and plug things up again days or weeks or years later.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
