RV.Net Open Roads Forum: Easiest way to fill air to rear tires on dually
Search only in Tow Vehicles
 > Easiest way to fill air to rear tires on dually
pigbike
Posted: 02/22/12 07:38am Link  |  Print  |  Notify Moderator
The extensions come in 3/4" and 1 1/4". I was going to try 3/4 first but couldn't fine any locally. I ended up buying 1 1/4", and now feel the 3/4 might of been too short. It all depends on the lenght of you tire valve stem. Mine were short to begin with, so 3/4 might not of been long enough to get the inflator on without bending and stressing the valve stem.
philand
US
Posted: 02/22/12 09:11am Link  |  Print  |  Notify Moderator
I have the pressure transmitter on 6 tires, no extensions. Considering getting extensions, since nearly impossible to remove transmitter and inflate. Anyone have suggestions? Looks like most say to get metal (ridgid) extensions, but then have to dismount the tire. Maybe wait till I need new tires.
MikeSD
Tennessee
Posted: 03/01/12 03:50pm Link  |  Print  |  Notify Moderator
I use a standard-size air chuck on my air compressor that reaches the inner valve stems no problem-
However, it's important to install the outer wheel on the studs so that one of the 'holes' in the outer wheel overlaps where the valve stem is on the inner wheel, so you can just stick the air chuck through the outer 'hole' to reach the inner valve stem.
Hope that helps-
2002 Ford F-350 Lariat CC, LB 4x4 7.3L PSD
2006 Jayco JayFlight 27BH
stubblejumper
Saskatchewan
Posted: 03/01/12 05:11pm Link  |  Print  |  Notify Moderator
If you look at your rims the is a small ( approx 1/4") hole outside the mounting holes ring. In the case of dualies these holes must match up when the wheels are mounted resulting in the holes in the rims properly matching up.
1999 Winnebego Chieftain
Wayne & Leila and Teddi (the Kid in the brown fuzzy pyjamas)
We are not 2 people that own a dog, we are 2 people that are owned by a dog ..
4x4ord
Canada
Posted: 03/01/12 11:31pm Link  |  Print  |  Notify Moderator
I would just check the outer tires as you probably don't need any air in the inners anyway.
Just sort of kidding - use a long handled air chuck.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
conmoto
Northern Illinois
Posted: 03/02/12 12:07am Link  |  Print  |  Notify Moderator
That air chuck is what I use as well.
snowdance
Yreka, Ca
Posted: 03/02/12 05:06am Link  |  Print  |  Notify Moderator
I use the long one but added about 8 inches of 1/8th pipe to it so I can get a good grip on it.. Works great.. On mine I have stainless hubcaps I have to pull to check the rear.. They look nice but a PIA..
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
milsuperdoc
barn
Posted: 03/02/12 03:25pm Link  |  Print  |  Notify Moderator
What brand is this long handled air chuck? Where can I buy one?
SoCalDesertRider
SanDiego, CA, USA
Posted: 03/04/12 08:18am Link  |  Print  |  Notify Moderator
buzzard616 wrote:
These are what I had on a Ford E 450 class C.
The setup is called a 'Dually Valve'
This isn't a great picture but it does show where the stems come out.
These stems are solid brass; totally rigid.
They are available from (among other places):
Tire-Man.com
Stu
I have those on my dually. They work great.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
