RV.Net Open Roads Forum: Sedona to WIlliams AZ route for Class A and toad
 > Sedona to WIlliams AZ route for Class A and toad
balfre1946
travelling
Posted: 02/21/12 06:14pm Link  |  Print  |  Notify Moderator
We are in Sedona heading north and west to Willians and Las Vegas. Looks like we need to double back south on 179 to I 17 north because 89A north from Sedona looks pretty torturous for a 36ft class A towing a Porsche on the ground. Any recommendations?
rk911
Wheaton IL
Posted: 02/21/12 06:20pm Link  |  Print  |  Notify Moderator
I-17 north to I-40 and then west. 89A north from sedona would be a reallt, really slow go for you.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
sp8gold
Colorado Springs, CO
Posted: 02/21/12 06:31pm Link  |  Print  |  Notify Moderator
We came down 89A from Flagstaff with a 42' and 2-45' all towing. Some of the corners where tight but we had no problems. Just have to take your time.
WylieWanderings
Arizona
Posted: 02/21/12 07:02pm Link  |  Print  |  Notify Moderator
Living here in the Verde Valley, I would DEFINITELY go up I-17 to 40 West. Drive 89A in your toad, not the MH.
2012 Heartland Road Warrior 305, 2007 Chevy 3500HD Duramax/Allison dually
"Content makes poor men rich; discontent makes rich men poor."- Benjamin Franklin
Executive
Posted: 02/21/12 09:29pm Link  |  Print  |  Notify Moderator
Listen to the CowGirl.....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
FIRE UP
Ramona, CA. USA
Posted: 02/21/12 10:35pm Link  |  Print  |  Notify Moderator
balfre1946,
We've done that road several times. We've done it with Class As, Class Cs and motor cycles. Yes, it's a bit windy, yes in a few spots it's a "little" tight, yes in a few spots it's a little steep but, all of it is doable with a 36' unit. There are people that do it all the time. No it's not the most easily traveled section of road for a rig like yours but, it is the shortest route to your destination of Williams. There are a few pull-out spots for you to allow built up traffic behind you to slip on by.
If you look down at the other end, towards Gerome and Prescott Valley, it's seriously longer and has a considerable amount more "twisties" in it. You are, just about in the middle of that route. You will have about 15 minutes of twisting and climbing and then it smooths out towards 17. If I may ask, where are you staying in Williams? We really like Kaibab Lake State Park, but, it's most likely closed at this time of year.
One has suggested that you drive the toad and not pull it up that route. That's a great plan. It will make it a lot easier on the climb. We've done that in many climbs and routes. We did it on the route of 550 out of Ouray CO, up to the summit where we hooked up. We occasionally do it on the Montezuma Grade out of Borrego to Ranchita CA and hook up there. It' simple and easy that way. And it's a relief on the coach.
You'll have no problems running that short climb out of Sedona.
Scott
Scott and Karla
SDFD RETIRED
2011 White Honda CRV EX-L,4WD w/NAV Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
balfre1946
travelling
Posted: 02/21/12 11:19pm Link  |  Print  |  Notify Moderator
Thanks for your reply. With a Porsche Carerra conv. it is no big deal to tow and a much bigger pain to connect and reconnect. We are not really into state parks..too far off the main road, often no hookups and often not pet friendly. We like the ammenities of a full service RV park since we are oding this for more than a year.
Dick_B
Palos Heights, IL USA
Posted: 02/22/12 06:38am Link  |  Print  |  Notify Moderator
Avoid 89A north of Sedona UNLESS you want to add your paint to the existing layers on the overhanging rock ledges. Yes, the long way is the best way for any RV.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Lady Fitzgerald
Tempe, AZ, USA, Earth
Posted: 02/22/12 09:14am Link  |  Print  |  Notify Moderator
I agree that 179 back to I-17 would be best. 89A is doable but you would be crawling and would have to take up both lanes in many of the hairpin turns, something that oncoming traffic...ah..will have little appreciation for. You will make far better time taking 179 back to the 17 and it will not be nervewracking like 89A.
Jeannie
LongWeekends
Scottsdale, AZ
Posted: 02/22/12 01:22pm Link  |  Print  |  Notify Moderator
X2
Michael
Just me, my wife, our 11 year old daughter and our two big, hairy Goldens.
2004 Coachmen Cross Country
370DS - 300HP - 2 Slides
