Crazy Ray
Monroe,La
No 12volt in 2000 Gulfstream without motor running. I have check ALL fuses. What am I missing? Thanks
edited 02/21/12 06:26pm by an administrator/moderator *
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
JohnnyT
Goshen New York
Ray, I really hesitate to mention this but usually there is a 12 volt master switch for the house...
JohnnyT
Shadow Catcher
NW Ohio
A VOM is your friend, Check for voltage from where you have it to where you don't.
Crazy Ray
Monroe,La
Johnny T I have tried that switch and NO light comes on for the HOUSE. Chassis light is on but no house light.
Crazy Ray
Monroe,La
Voltage does NOT show without motor running. Next shot.
MrWizard
Traveling
could be the house batteries are dead
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
enblethen
Moses Lake, WA
There should be a battery disconnect for the coach batteries. It needs to be switched on.
You may need to check further with a test light or meter as there could be a circuit breaker that has tripped normally located adjacent to the battery disconnect.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Crazy Ray
Monroe,La
Voltage reads 12.76 just went out and checked it
rvrepairnut
bc
Crazy Ray wrote: No 12volt in 2000 Gulfstream without motor running. I have check ALL fuses. What am I missing? Thanks
The batterys must be dead.No other reason.I bet if u run genset assuming u have one(genset) the same thing occours.Lites will work
same as engine running
rvrepairnut
bc
enblethen wrote: There should be a battery disconnect for the coach batteries. It needs to be switched on.
If the 12 volt disconnect is off u will have no 12 volts supply even when engine running.He say he has 12V when engine running
