RV.Net Open Roads Forum: Class A Motorhomes: 12 volt system
 > 12 volt system
Crazy Ray
Monroe,La
Posted: 02/21/12 06:18pm Link  |  Print  |  Notify Moderator
No 12volt in 2000 Gulfstream without motor running. I have check ALL fuses. What am I missing? Thanks
* This post was edited 02/21/12 06:26pm by an administrator/moderator *
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
JohnnyT
Goshen New York
Posted: 02/21/12 06:29pm Link  |  Print  |  Notify Moderator
Ray, I really hesitate to mention this but usually there is a 12 volt master switch for the house...
JohnnyT
Shadow Catcher
NW Ohio
Posted: 02/21/12 06:38pm Link  |  Print  |  Notify Moderator
A VOM is your friend, Check for voltage from where you have it to where you don't.
Crazy Ray
Monroe,La
Johnny T I have tried that switch and NO light comes on for the HOUSE. Chassis light is on but no house light.
Crazy Ray
Monroe,La
Posted: 02/21/12 06:41pm Link  |  Print  |  Notify Moderator
Voltage does NOT show without motor running. Next shot.
MrWizard
Traveling
Posted: 02/21/12 06:42pm Link  |  Print  |  Notify Moderator
could be the house batteries are dead
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
enblethen
Moses Lake, WA
Posted: 02/21/12 07:51pm Link  |  Print  |  Notify Moderator
There should be a battery disconnect for the coach batteries. It needs to be switched on.
You may need to check further with a test light or meter as there could be a circuit breaker that has tripped normally located adjacent to the battery disconnect.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Crazy Ray
Monroe,La
Posted: 02/21/12 08:10pm Link  |  Print  |  Notify Moderator
Voltage reads 12.76 just went out and checked it
rvrepairnut
bc
Posted: 02/21/12 08:51pm Link  |  Print  |  Notify Moderator
The batterys must be dead.No other reason.I bet if u run genset assuming u have one(genset) the same thing occours.Lites will work
same as engine running
rvrepairnut
bc
Posted: 02/21/12 08:52pm Link  |  Print  |  Notify Moderator
If the 12 volt disconnect is off u will have no 12 volts supply even when engine running.He say he has 12V when engine running
 > 12 volt system
