RV.Net Open Roads Forum: Class A Motorhomes: 12 volt system
 > 12 volt system
Maanpa
Where Ever We Rest Our Head
Posted: 02/22/12 03:48am Link  |  Print  |  Notify Moderator
Check to see if your Aux. Battery Switch is on. I had the same problem your having and that was my problem after hours of checking. Put a volt meter on you house batterys and if they are charged.If so I would bet this is your problem. Good Luck.
Koran & Darlene
Creole, Cajun (Our 4 Legged Kids)
2007 Itasca Suncruise 38T
2004 Rubicon
Yankee Clipper
Cairo, GA
Posted: 02/22/12 06:33am Link  |  Print  |  Notify Moderator
On my rig there are three solenoid switches in the battery compartment. Two are identical, and they serve to isolate the batteries for storage (one for the two coach batteries and one for the chassis battery). The third solenoid functions to cross-connect the 12v systems for an emergency start.
If the emergency start button on the dash restores the coach 12v power, you have a faulty isolation solenoid that is stuck in the storage mode.
You didn't mention whether the shore power provided 12v functions.
Anyway, HTH.
Yankee Clipper
1997 Coachmen Catalina 330MB on F53/Ford 460efi
1991 Explorer Sport 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS
Not overly concerned about depreciation with this rig...
Crazy Ray
Monroe,La
Posted: 02/22/12 04:10pm Link  |  Print  |  Notify Moderator
Yankee Clipper I do have 12Volt power hooked up to shore Power. what next?. Thanks
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
Yankee Clipper
Cairo, GA
Posted: 02/23/12 11:46am Link  |  Print  |  Notify Moderator
In my experience you're back to the isolation solenoid. Look to see whether you have a panel labelled IntelliTec, which in my case has two rocker switched on it.
You might try cycling the storage switch for the coach battery several times to see whether the solenoid will catch on the "Use" side. Mine sometimes doesn't connect on the chassis battery, and this has worked.
If you have a bad solenoid, I've seen them on eBay for $58. IntelliTec part number 355-721 is what I have in my repair notes.
Best of luck!
enblethen
Moses Lake, WA
Posted: 02/23/12 12:18pm Link  |  Print  |  Notify Moderator
Locate your battery disconnect relays. Use a test light or meter to see if battery power is on battery side, next cycle the disconnect with the switch(have helper do this while you listen for the relay to operate), check the coach side of the relay for battery power(shorepower disconnected). Should have the same voltage on each side if it is operating.
Look around the same are for a small DC circuit breaker. It could be tripped as some have a small button to reset. Others are not resetavble and must be replaced. Check both terminals of circuit breaker for battery voltage(shorepower disconnected)
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
rvrepairnut
bc
Posted: 02/23/12 12:28pm Link  |  Print  |  Notify Moderator
Running the engine alternater does not bypass the 12V disconnect switch to the coach 12V system
Crazy Ray
Monroe,La
Posted: 03/05/12 02:03pm Link  |  Print  |  Notify Moderator
To all who gave me GOOD answers to my problem. I have found my problem, when I took my solar off I took the ground cable off and did not put it back on. So thanks . My mistake
Just Bob
SD/CT/FL/WY
Posted: 03/05/12 03:39pm Link  |  Print  |  Notify Moderator
All's well that ends well.
Wherever I happen to park
Posted: 03/05/12 06:26pm Link  |  Print  |  Notify Moderator
Suspect #1 is usually.... Bad Grounds.
Glad you found it.. And one Phrase of comment"
IF that's the worst mistake you ever make....
Mr. you're a better man than I.
 > 12 volt system
