RV.Net Open Roads Forum: Tech Issues: Eternabond
 > Eternabond
BARRY2010
North Ga
Posted: 02/21/12 08:23pm Link  |  Print  |  Notify Moderator
I was thinking about putting Eternabond tape along all the seams and around any place on the roof that has caulking. No leaks - just thought this may be a good preventative measure. What do you think ?
coolmom42
Middle Tennessee
Posted: 02/21/12 09:00pm Link  |  Print  |  Notify Moderator
We are planning on doing the same. Will be interested to see what others have to say about it.
2006 Toyota Sienna
Single empty-nester in Middle TN
smkettner
Posted: 02/21/12 09:29pm Link  |  Print  |  Notify Moderator
EB seems too permanent. I touch up with Dicor as needed once a year and seems good to go.
I will wait for a real disaster to pull out the EB such as a tree branch rip.
675 watts solar
oldbeek
lancaster CA
Posted: 02/21/12 09:55pm Link  |  Print  |  Notify Moderator
Why does DICOR need to be touched up each year? Have hears this befor. Is it not the same as EDPM 2 part coating?
1994 27sl Alpenlite, 2001 Dodge Cummins auto 3.54 stock
fordsooperdooty
Posted: 02/21/12 09:59pm Link  |  Print  |  Notify Moderator
Barry has it exactly right...EternaBond it and forget asbout it! Do it right the first time, follow the EternaBond Website suggestions including when to use the EternaPrimer.
Rolling it out after applying is a "must do", as that's what bursts the micro-encapsulated beads in the tape, releasing the incredibly strong adhesive!
Alpenliter
Fulltimer: Wherever we are!
Posted: 02/21/12 11:19pm Link  |  Print  |  Notify Moderator
X2
As far as touching up the Dicor, yes it can crack through expansion and contraction over time. Not so with Eternabond.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
Golden_HVAC
Fulltime, CA, USA
Posted: 02/22/12 02:03am Link  |  Print  |  Notify Moderator
Coat the whole roof, and forget about it, and don't worry much about branches, only the trees falling across the roof.
[ur=http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24993453.cfm]http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24993453.cfm[/ulr]
And no more white streaks.!!
There was a post recently about a guy painting whole trucks with 1/4" thick truck bedliner, and doing all the seams on a RV as well as the roof. It certainly cuts down on the rain noise.
Fred.
John&Joey
Some Location
Posted: 02/22/12 02:58am Link  |  Print  |  Notify Moderator
No Dicor is a caulk not a coating. Doing it every year is a myth, it will start to show it's age somewhere between 5-10 years after applying (depending on where you are in the country.) The yearly part comes from just being pro-active and checking the roof at least once a year.
ET is good, Dicor is good. ET is overkill (when no leaks) and is very ugly to my eye. That's the only reason I don't like it. Everytime I see a rig with it I think the owner must have had a leak somewhere, and is now covering up internal damage. To be found by the next owner who bought the rig. IMHO, using lots of ET decreases the resale value.
gbopp
The Keystone State
Posted: 02/22/12 04:25am Link  |  Print  |  Notify Moderator
x3, then coat it following the info posted by Golden_HVAC.
Klueck
Posted: 02/22/12 05:17am Link  |  Print  |  Notify Moderator
When we had Dicor, we fouund it MAY last 6 months before we would find little tiny pinholes (leaks). We're in Florid where the sun is hot. It doesn't take the flexing and change in temperature like Eternabond does.
We went to Eternabond and don't have to worry about it again.
 > Eternabond
