RV.Net Open Roads Forum: Fifth-Wheels: FW Brake Screech, or what's the problem?
 > FW Brake Screech, or what's the problem?
phillyg
Front Royal, VA
Posted: 02/22/12 06:29am Link  |  Print  |  Notify Moderator
One of the brakes on one side of my trailer has developed a problem that I can't identify. After the brakes have been used a bit, I'm getting what I can best describe as a loud screech(sp) in the last 20-40 feet the stop. It's not a squeal, and it's not the metal-to-metal sound you get when the shoe is worn out and rubbing the drum.
I serviced the brakes some 2,000 miles ago and all had plenty of shoe left, and the magnets checked out okay. I also repacked the bearings and adjusted the shoes per mfgr's spec. I've checked all four wheels with an infrared thermometer every time I've stopped between VA and FL, and all have been within 10 degrees (90-100) of each other. I have Al-Ko axles but I think the brakes are Dexter, if that makes any difference. I'm hopeful some of you may be able to identify this problem.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
danojeno
Corona, CA
Posted: 02/22/12 07:24am Link  |  Print  |  Notify Moderator
No solution to offer, but I have the same issue and have had it since the trailer was new. I took it back to the factory service center but it continued so i need to take it in again. Mine is sometimes accompanied sometimes by a wheel locking up and bucking coming to a complete stop.
2006 Chevy 2500HD 8.1 4x4 CCSB
2012 Eclipse Stellar 28SBG, Spring Over Axle
Dave H M
IL
Posted: 02/22/12 07:38am Link  |  Print  |  Notify Moderator
don't ya have to pull the drum and have a look see.
If one in four does it there is something not right in there?
jesterdog
Posted: 02/22/12 07:41am Link  |  Print  |  Notify Moderator
On a car with disc brakes, the squeal is from a vibrating disc pad. What you do is remove them and apply high temp brake grease to the back of the pads (the non friction side that contacts the caliper). This quiets the squeal that can be intermittent. But you have drums it seems. Don't know if this applies to your situation. Not sure if there are grease points that would solve the problem with the shoes.
2001 Excursion 3.73 geared V-10
2007 R-Vision Trail Lite 8311S
Vulcaneer
Northern New England
Posted: 02/22/12 07:57am Link  |  Print  |  Notify Moderator
I would be suspicious of a little grease on the braking pad surface of the shoes. The oil in the grease will soften the pad and that makes it grabby and it can squeal or screech, when the wheel slows down to a certain speed.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto, Ultimate Lariat pkg
2011 Open Range 393RLS 14,250 GVWR
Pullrite Super Glide 18K
SHORT FLAGSTAFF
Posted: 02/22/12 08:14am Link  |  Print  |  Notify Moderator
Good Morning: This condition can be caused by either what is called a glazed drum or a hard brake shoe or both if it were me I would have the drum turned and replace the shoes on that wheel. Good Luck.
larry barnhart
wenatchee. wa usa
Posted: 02/22/12 08:23am Link  |  Print  |  Notify Moderator
man had this problem in an rv park we were using in 2001. It would drag when stopping on gravel. tight was our thinking but after going for a repair the rv tech said that brake was too loose. It did not drag arriving into their site coming back so ???
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Paul G.
SW, MN
Posted: 02/22/12 08:57am Link  |  Print  |  Notify Moderator
Mine does the same thing when the brake pads need adjusting. From what I have read it has something to do with the throw or distance the pad travels, too far from the drum it tends to squeel and grab. I would start with a brake adjustment.
Paul...
stripit
Casa Grande, AZ
Posted: 02/22/12 09:13am Link  |  Print  |  Notify Moderator
Mine did the same thing so pulled the wheel, then the drum and found the clips that kept the magnet in place gone. Have no idea how it could disappear, but it was not there. Bought a packet of new clips and replaced the missing one and the noise went away. Also checked for adjustment of the brakes while I had the trailer jacked up, took a few minutes and might as well do it while you working there. If the noise was 'normal' they all would be doing it, not just one.
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'08 Lexus 400H
mapguy
Puget Sound
Posted: 02/22/12 09:43am Link  |  Print  |  Notify Moderator
1. Newbies almost always adust trailer brakes to loose. If the tire rotates more than ~3/4 of a turn from a moderate spin -it is too loose. You will hear the brake shoe scrapping the drum -if the shoe is properly adjusted. The scrapping sound is the leading edge of the shoe hitting the drum.
2. If hardware, shoe lining, wiring/magnets and adjustment are all ok but the squeal continues -it is time to taper the leading edge of every shoe in an approximate 3:1 ratio to eliminte the high spot contact pattern on initial brake application. This will allow more of the shoe to actually contact the drum and eliminate the squeal/chatter at initial brake application.
In the "old" days brake shoes were "arced" or ground to fit drum diameter. This is not done today as a normal procedure for several reasons including cost and environmental hazard.
Good luck!
