RV.Net Open Roads Forum: Class A Motorhomes: Cracked Shower Pan
 > Cracked Shower Pan
wvumountie
Posted: 02/22/12 06:58am Link  |  Print  |  Notify Moderator
I have a 2002 Winnebago Journey, the shower pan is cracked. It is cracked right where the lip angles down. I have tried to caulk it but everytime you put weight in the shower it opens right back up. I priced out the shower pan and it is over $500 just for the part to replace.
I was thinking of other ways to repair it. One thought is to use roll on truck bed liner, it has the grit to create a non slip surface, while sealing it with rubber. Does anyone have any thoughts on this?
jmduc
Canada
Posted: 02/22/12 07:07am Link  |  Print  |  Notify Moderator
REMOVE THE PAN IF POSSIBLE AND FIBERGLASS IT.
wvumountie
Posted: 02/22/12 07:10am Link  |  Print  |  Notify Moderator
from underneath obviously? You do not think the bed liner would work?
weathershak
Not sure, I need to look out the window
Posted: 02/22/12 07:12am Link  |  Print  |  Notify Moderator
There should be an access panel to get under the pan to get at the drain pipe. You may be able to shim something up under the pan.
Full timing it since July 2012 My pics
Ed9824v
Agua Dulce, Calif. 70 mi S.E. of Los Angeles
Posted: 02/22/12 07:15am Link  |  Print  |  Notify Moderator
YEP, I called the factory and they told me to use fiberglass cloth and resin.. the big BUT I was able to access the crack from the bottom from the front panel. This was a while ago so if I recall I first ruffed up the surface and put a coat of resin on the underside and then when dried put a couple of coat of resin impregnated fiberglass cloth. The BIG THEN I was able to put Styrofoam in the corner for reinforcement. closed it up and it never leaked again and was nearly inadvisable from the top.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
wvumountie
Posted: 02/22/12 07:18am Link  |  Print  |  Notify Moderator
Mine is in the far back corner, I will need to remove the shower doors to get the pan out. But that is probably the right way to do it.
rgatijnet1
Posted: 02/22/12 07:21am Link  |  Print  |  Notify Moderator
I would see if you have access underneath to place shims or put something underneath the pan to prevent flexing. After you have stabilized the pan then I would patch the crack on top with fiberglass cloth and resin to seal the crack. After that, if you want the non-skid surface, I would use the truck bed liner material as a top finish coat. If you CANNOT stabilize the pan to prevent sagging, which may be cause by rotted under-layment from previous leaks, then I don't think the bed liner material would offer a lasting repair.
wvumountie
Posted: 02/22/12 07:24am Link  |  Print  |  Notify Moderator
I will check for access underneath, it seems that is key.
Scottwig
Belvidere, IL
Posted: 02/22/12 07:33am Link  |  Print  |  Notify Moderator
I fixed a 4" crack in the tub of our Damon Daybreak with J-B Weld and it's held up for 2 years, so far. It doesn't look pretty but it doesn't leak and was a lot cheaper and easier than replacing the tub or trying to patch with fiberglass.
Scott and Janet Hartwig
Rocky and Moose, long-haired mini dachshunds
2006 Damon Daybreak 3270F (F53 V-10)
Tandem Tow Dolly with Honda 750s, Aero and Spirit C2, and Ford Focus
Oasisbob
Portland Oregon 97266
Posted: 02/22/12 07:40am Link  |  Print  |  Notify Moderator
Those whose shower pan has not cracked beware. I am told RV's in that ear, mine included, have this problem due to there not being enough pan support under the shower floor. I added aditional support to mine. If your shower pan does not feel solid when you stand on it give some thought to better support before it does crack. I had to make an access panel through underside of trailer. Servicing after the fact is rarely on the minds of the RV industry. Best of luck.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
