Bucky Badger
Madison, WI
Drop in's are so 90's...
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
aquarious
Marion Indiana
I have a drop in and would have no other. Ed
old guy
Oregon (pronounced Or e gun)
the drop in's always have rust under them and as mentioned things slide all over the place. I thought I was going to lose a gen set on day. I got spray in this time around
john b
anywhere USA!
I have an 2001 truck & the drop in has been in it since new. I have removed it three times because of hearing all the horror stories on this forum & others but it still looks like new under there,
After the hitch was installed I took it out to be sure no steel shavings were left & there were a few.
Ninety dollars 11 years ago great deal and would do again if I purchased again. $ 5 to 8 humdred dollars don't grow on trees.. With our experience I need what works,
not to keep up with the joneses or keep it nice for the next owner!!!
JMHO jb
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
mlts22
Austin, Texas
I've had a drop in on both my trucks. However, my next truck, I will get a Line-X (that specific brand) spray-on.
Line-X is epoxy based, and is applied using a resin/hardener. I've seen other brands which use solvents and just dry. Line-X cures, which is a big difference in life.
Of course, regardless of brand of spray-in/painted-on liner, prep is key. Not getting the dirt and oil off the metal before spraying or painting will kill any liner, no matter how good it is.
Major Dad
San Antonio TX
Drop in bedliner because (1) it came with the 2010 Ram 2500 and cost me NOTHING EXTRA (2) I can slide items into position and offload them easily by sliding the items where I need them to go (3) I secure MY loads with bungees or rope so nothing shifts.
2008 Rockwood 8272S
2010 Ram 2500 Lone Star CTD 4X4 Megacab
DH+DW 32+ years
Molly the flat-coated retriever
Millie the fawn brindle greyhound
dmax_83
SE WIsconsin
Another vote for spray in liners. I have Line-X and would not have anything else.
1998 Jayco Eagle 302FK (Honda EU3000is)
2011 GMC Sierra 2500HD 4x4 Duramax/Allison
2003 Honda Aquatrax F-12X Turbo
turninghawk
Orlando, FL
tshirtman wrote: What do you all think??
Spray in liner or drop in for new TV
So you, like many others, are convinced you MUST have a bedliner of some kind, right?
PM me, and as an automobile dealer and avid RVer, I can tell you why they are not always a good idea, and what other options you probably have not even considered.
(Kind of like the 3000-mile oil change intervals 'invented' be the quick oil change places!)
MitchF150
Washington, the State
Wow, I didn't know the spray in cost that much! Between $500 - $800! Wow..
Never priced them because I've always just had the drop in and the bed is still bolted to the frame, so I guess it's not rusted that badly yet!
I too was going to pull mine to see how bad it was... Took one look at how it was installed and said forget it! It's screwed in place with about a dozen self tapping screws.. No way was I going to pull them and try to line them backup again!
The bed is just going to have to rust off before it comes out!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
Padlin
W. Ma.
Another that's had both, not crazy about either. I now use a rubber mat and also have a drop in that I got used for nothing. The drop in is only used to haul dirt, rocks and so forth, covers the wood pile the rest of the time. I did have the ded on my old Mazda B2200 (Ranger) rot out under the drop in. I do remove the mat a couple times a year to clean it out. I use a cap a lot and find the spray in too rough for climbing around on. For 70 bucks you can get a mat and always change to one of the others options later if you find the need.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
