RV.Net Open Roads Forum: Tow Vehicles: Lowering a 2011 Dodge 3500 4x4 dually
Search only in Tow Vehicles
 > Lowering a 2011 Dodge 3500 4x4 dually
USMA Dad
Stuart, FL
Posted: 02/22/12 03:21pm Link  |  Print  |  Notify Moderator
Has anyone successfully lowered a Dodge 4x4 dually? I tow a 43' TH and have sufficient bed clearance EXCEPT when the truck is angled nose down - at that point I'm within 1 inch of the underside of the TH. I've already cracked the cargo light mounted next to the pinbox. I know I can lower the pinbox and gain about 3 inches; however, the TH tows level and I don't want to lose that. I'm not looking to turn the truck into a "lowrider" just maybe the height of a 2WD without compromising the undercarriage of the truck.
Thanks in advance for your thoughts...
Don Z.
'04 Dodge CTD 2500 SRW
'12 Jayco Recon ZX 39A
oh yeah, and the wife, kids, and dogs!
Diesel is cheaper than beer. Who's gonna stop drinking???
Member of the Masonic group RVTravelingMen
MadMav
Colorado Springs, CO
Posted: 02/22/12 03:36pm Link  |  Print  |  Notify Moderator
Save the money and spend some time getting the pin/hitch setup just right. Tons of folks are towing very similar setups without clearance issues.
Throw a picture up and see if we can help.
Mav
* This post was edited 02/22/12 08:30pm by MadMav *
"A fifth wheel trailer is a bi-level towable mobile home."
45Ricochet
North Idaho
Posted: 02/22/12 04:39pm Link  |  Print  |  Notify Moderator
I drove around a couple of years with 4" of clearance. Never did make contact but I got tired of checking the mirror every time I entered a driveway. Finally changed my pin box to get a extra couple of inches.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
donn0128
Pronounced Ore-gun
Posted: 02/22/12 05:08pm Link  |  Print  |  Notify Moderator
Can you raise the trailer some more? That was what I had to do to get more room.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
johntank
North MS
Posted: 02/22/12 05:19pm Link  |  Print  |  Notify Moderator
You can have the blocks taken out from between the springs and rear axle that will drop the rear down about 2+", but that makes it hard to change the rear brake pads when it's time.
rehoppe
Denver & Nathrop Colo or somewhere else
Posted: 02/23/12 05:54am Link  |  Print  |  Notify Moderator
How about dropping the blocks, and installing airbags? That way you can bring it back up when if needed and you'll have a better ride?
Hoppe
2011 Dodge 1500 C'boy Caddy
2000 Jayco C 28' Ford chassis w V-10 E450
Doghouse 36' or so Trophy Classic TT
SoCalDesertRider
Arizona desert
Posted: 02/23/12 06:35am Link  |  Print  |  Notify Moderator
I would ditch the pickup bed and install a flat bed with under bed boxes or a hauler bed. No more bed rail height issues and you have a much more useful cargo bed with a lot more secure storage capacity too.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
rehoppe
Posted: 02/23/12 06:55am Link  |  Print  |  Notify Moderator
What size wheels and tires you have on it? Smaller wheels Might be an option but it would also shrink your ground clearance.
I've get 20"ers on mine, tire shop says I can go as small as 17"s. Was considering putting 'take off' tires off my MH on it to use them up, before they 'rot', but 16's won't fit the brakes. I'm looking for higher profile, better sidewalls, and easier in and out, w/o nerf bars or boards.
I've always thought the only trucks that should need steps are Monsters and Class 7 and 8s.
whisperide
Golden Spike area
Posted: 02/23/12 06:39am Link  |  Print  |  Notify Moderator
Drop it at least 4" all around. This will noticeably improve MPG and handling, without hurting anything. Also helps getting in and out of the cab, and reaching over the sides of the box. Best way to lower the front is shorter springs. Start with removing blocks in the rear, then if that's only 2", get some Bell Tech 2" shackles. I love mine! Excellent return on investment.
'06 GMC C2500HD RCLB gasser 4.10:1, 4L80E, custom camshaft
'84 Trans Am 6.2 diesel, 700R-4, custom Class-3 receiver
'69 F350 dually. GM 6.2 diesel, turbo, 700R-4, NP208 all pending.
rehoppe
Posted: 02/23/12 02:47pm Link  |  Print  |  Notify Moderator
Looks like it's doable even with the stock 20"s on. Did you have to change shocks?
