I am trying to determine what I should do for extended mirrors for my 2010 gmc sierra 1/2t, I have power and heat on my current mirrors, if I purchase aftermarket mirrors with power, heat and turn signal will they plug in and work they way they should or will I need to do some wiring to get the turn signal up to the mirrors? I would assume the heat and power will work?
2010 Sierra 4x4 1500, 5.3L 3.73
2012 Jayflight 26BH
I have read that the aftermarket OEM towing mirror clones will plug right in and have the signal work too. The only complication comes from if you have memory seats/mirrors, which you do not.
A & A parents of DD 2005, DS1 2007, DS2 2009 2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS 2012 VW Passat TDI
I had the power vision mirrors installed on my 2007, just had to order the right head that includes what your truck has and it plugs right in. The only function that was a bit off was the different drivers options for seat and mirror auto adjustments.
Lord, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of those people I had to kill because they pissed me off.
