msmith1199
Central, CA
Yes another tire question. My MH currently has Michelin XRV 255/80r 22.5 tires on it. They are original tires so are at least 9 years old since the chasis is a 2003 while the motorhome is a 2004. One tire developed a leak so instead of going and getting the leak fixed I decided I may as well replace all six since many seem to think five years is pushing it and I'm going on nine years. The tire dealer also thought I was pushing the outter envelope too, but they want to sell me new tires.
So the question, the same Michelin tires would be $4500 out the door. Six Toyo tires are just at $3000 out the door. The only issue is Toyo doesn't make that exact size. The size I ordered are 265/75r 22.5/14 M-154. Tire guy says he's put these on other Freightliner chasis and never had a problem. He tells me these tires are the exact same weight rating as the Michelin's and are only two tenths of an inch difference in diameter. They will be I think he said two tenths of an inch wider too. I have a big distance between the existing duals so two tenths of an inch won't make them touch.
I have ordered the Toyo's but it's not too late to cancel. Anybody see any issues with this?
edited 02/22/12 07:19pm by msmith1199 *
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
Ro646a
New Boston, MI
My two year old Michelin tires are already developing sidewall cracks and Michelin says this is normal. I bought those tires to replace the 10 year old Goodyears that were on it when I bought it, and those Goodyears that I threw away still looked like new.
I hope you have better luck than I did.
2001 Fleetwood Southwind 35R on 2000 Ford F53 Chassis
V10 310HP
Roadmaster Sterling All terrain tow bar
Ready Brake
2002 Chevy Tracker V6 4x4 SUV
sriethman
Ohio
You are fine if you go with the toyos! Michelin makes their own size tires on most rv and heavy duty trucks. Good luck with the toyos!
1999 Newmar American Star
2002 Ford F-250 Crew Cab 4X4 5.4L
Me 28
DW 27
Pogoil
Oregon Coast
I now have 6 Toyo M154 on my 33 foot MH 265/75/22.5 and I like them. I personally would have not bought the Mich. if they were less than the Toyos. Just my opinion based on what I have seen on the side walls.
By the way the 4 Toyos that Came off the back of the MH. were 9 years old and I inspected them after they were dismounted and could not find any cracks any where on any of the 4 tires. They looked almost as new as the day they were installed.
Pogpol.
msmith1199
Central, CA
The current Michelin tires on it do have the sidewall cracks. I've heard so many different stories on what that means it's hard to tell who to believe. I don't think you need to swap tires out at 5 years, but I do think I'm pushing it with 9 years. I have seen older tires blow out so I know it happens. The issue is just how long before you need to worry about it? I also have plenty of tread left and it just doesn't feel right to spend $3k for tires when the ones on it look just fine, but I guess that's the cost of owning a RV.
msmith1199
Central, CA
Pogoil wrote: I now have 6 Toyo M154 on my 33 foot MH 265/75/22.5 and I like them. I personally would have not bought the Mich. if they were less than the Toyos. Just my opinion based on what I have seen on the side walls.
Pogpol.
I had to edit my orginal post to fix the M154. That is exactly the tire I ordered. I was expecting to get prices in the $5k range for six tires so I was happy to see the $3k. According to my wife's logic that means I saved $2000 so I get to go buy something with it!
Mr.Mark
California/Tennessee
Ro646a wrote: My two year old Michelin tires are already developing sidewall cracks and Michelin says this is normal. I bought those tires to replace the 10 year old Goodyears that were on it when I bought it, and those Goodyears that I threw away still looked like new.
My current '06 tires with 50,400 miles don't have any cracks. I would be livid if I spent good money for new tires that developed cracks after two years. Looks like I would be on Judge Judy to get things settled!
My plan is to replace our current tires at the end of this year or early next for new Michelins since I've had good luck with my current tires. (295/80R/22.5).
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
JC2
Mo
Hankooks would be an option also and should run about what the Toyos are or less. If you were a member of FMCA, the tires size you mentioned in the Michelin brand would run about $476 each through the FMCA club tire program.
http://www.fmca.com/images/stories/pdf/michelin-prices.pdf
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
Weathertodd221
FL
why are those michelins so expensive?? $4500 is about $1500 more than what they should cost.
BobR
Aurora, Illinois
I just replaced 12 year old Michelins with Michelins again. My first two sets served me well with no cracking. I inspected the inside of the tires and there was no evidence of deterioration there either. Two commercial tire shops advised in the past if they don't leak air and not cracked they don't need replacement. After 12years, I decided that was enough service and changed out.
Since one has started leaking air and they are at least nine years old, I think it is a prudent decision to replace. By shopping the tires, I was able save 20% off the first three dealers quotes.
