RV.Net Open Roads Forum: Truck Campers: Realistic Weight on a 3500 Dually
 > Realistic Weight on a 3500 Dually
JaredWPhillips
Henryville, IN
Posted: 02/22/12 08:29pm Link  |  Print  |  Notify Moderator
Just got a 04.5 Dodge/Cummins 3500 Dually 4x4 NV5600 6-Speed. Always been a Cummins fan and owned several, but this is my first dually.
Shopping for a used Truck Camper, and trying to get cheap and functional. I don't mind some TLC, as I like customizing things anyway. I've seen some mid-90's TC's with wet bath's go on eBay for $1500-$2500. Decent condition, just needed a bit of love.
My question is, what realistic weight can I haul on my dually without adding extra airbags, springs, etc? I don't want to max it out either. My instincts tell me to find something UNDER 2000 lbs dry.
Any other 3rd-gen dually owners know the payload rating?
MY RVing BLOG
  • 2002 Chevy Suburban Z71 5.3 V8
  • 2001 Chevy Silverado 1500 ext cab 4x4 5.3 V8. GoodYear Wrangler Authority E-Rated tires, FireStone AirBags.
  • TT: 2010 KZ Spree 240 BHS
hmknightnc
Wilmington, NC
Posted: 02/22/12 08:44pm Link  |  Print  |  Notify Moderator
My '06 can do dang near 6,000# if using GAWR for the measuring stick. You'll be able to handle 4,000# with ease I would think. Your owner's manual should give you the information and chart for carrying payload
insp1505
Oregon
Posted: 02/22/12 08:55pm Link  |  Print  |  Notify Moderator
My 2005 Dodge dually has a payload rating of 4600 lbs. My fully loaded Arctic Fox runs about 5400 lbs. I don't use airbag's or extra springs. I have some home-made stable loads as my only suspension mod. It handles the load fine but I don't want to make it any heavier either as it weighs 8600 lbs on a 9300 lb rear axle capacity. In fact I have been considering removing the propane generator and AC since I rarely use either one.
Your truck won't even notice a 2000 lb camper on the back because your payload capacity is more than twice that. Enjoy!!
JaredWPhillips
Henryville, IN
Posted: 02/22/12 09:00pm Link  |  Print  |  Notify Moderator
Sounds good! Guess I can broaden my range when shopping.
sirdrakejr
Las Vegas, Nevada
Posted: 02/22/12 09:14pm Link  |  Print  |  Notify Moderator
I am carrying 3500# on my SRW 2004 Dodge Quadcab long bed CTD. Your dually ought to do better by at least 1000# I would think.
But I did add StableLoads and Timbrens with 19.5 inch Ricksons.
Frank
FireGuard
Ventura, Ca
Posted: 02/22/12 09:31pm Link  |  Print  |  Notify Moderator
I dont think 2000 lbs would even engage your overload springs.
3-4000 lbs would be a very "comfortable" weight.
I carried a Lance 1191 that weighed 5200 lbs wet and the truck handled it ok. It was a big load though.
17 Ram 3500 Tradesman,4x4 CC SB,CTD/AISIN
13Jeep Wrangler
07 Ragen FA 3005 (4 partners)
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
16 Polaris Razor XP 1000 Turbo
mountainkowboy
Socal
Posted: 02/22/12 10:56pm Link  |  Print  |  Notify Moderator
My old 1990 F350 Dually holds a 3400# camper. Scales at just over 10K, and the truck really doesnt care that its back there. Still have just over 1000#'s left on my rear axle rating for towing, and 9000#'s on my combined.
Chuck & Ruth with 4-legged Hanna...R.I.P. Dixie we miss you
Not camping much
06 Honda CR-V
11 Ford Ranger
78 CB750K
joe123
home
Posted: 02/22/12 11:09pm Link  |  Print  |  Notify Moderator
I have a 2001 Dodge dully, weighed truck on scale with full fuel tank weighed in at 7300 lbs, subtracted from gross vehicle rating I can carry 3500lbs in the box I am still legal on the highway up here in canada. the only mod to suspension was to have the overload adjusted and one more leaf added.hope this helps.
JIMNLIN
Oklahoma
Posted: 02/23/12 06:02am Link  |  Print  |  Notify Moderator
The '03 and up 3500 DRW Dodge has a 9350 RAWR. You payed for it so use it.
I would weigh the trucks front and rear axles seperatly that way you will know exactly what your max will be and if the TC has unloaded any weight off the trucks front axles.
Super_Dave
Harrisville, UT
Posted: 02/23/12 08:10am Link  |  Print  |  Notify Moderator
06' Dually as pictured below with a 2,800 lbs dry weight camper. Overload springs won't engage unless I extend the stops. I did put air bags on the rear just for head light leveling.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
