RV.Net Open Roads Forum: Truck Campers: Realistic Weight on a 3500 Dually
 > Realistic Weight on a 3500 Dually
2BLAZERS
KEIZER, OREGON
Posted: 02/23/12 08:21am Link  |  Print  |  Notify Moderator
JaredWPhillips wrote:
Just got a 04.5 Dodge/Cummins 3500 Dually 4x4 NV5600 6-Speed. Always been a Cummins fan and owned several, but this is my first dually.
Shopping for a used Truck Camper, and trying to get cheap and functional. I don't mind some TLC, as I like customizing things anyway. I've seen some mid-90's TC's with wet bath's go on eBay for $1500-$2500. Decent condition, just needed a bit of love.
My question is, what realistic weight can I haul on my dually without adding extra airbags, springs, etc? I don't want to max it out either. My instincts tell me to find something UNDER 2000 lbs dry.
Any other 3rd-gen dually owners know the payload rating?
For completely stock, I'd stick to staying under 4K in total loaded ready to camp weight. My AF 1150 basically is 5K loaded ready to camp but I've done airbags, stabiloads, and adjustable shocks which all work great.
And less if your going to tow much more then a small utility trailer or boat.
2016 Dodge Ram 3500 CC Dually Cummins,Aisin,Laramie,4*4,4.10,14K
2017 Stealth WA2916 Toyhauler
2011 Arctic Fox 1150 Drybath
2017 Polaris 1000 XP Sportsman
2009 Polaris RZR w/fun parts
2014 Polaris 850 HO Scrambler
1977 K5 Blazer 1ton'd
2005 Pace Enclosed Toybox
tkcrawford
Edmonton, Alberta
Posted: 02/23/12 08:47am Link  |  Print  |  Notify Moderator
I have an identical truck to yours. As you can see from my pic, it handles my Eagle Cap 995 just fine. I think the 995 is rated at 3300 lbs dry, so probably around 4000-4500 ready to roll. This is my fourth CTD and is, all around, the best truck of the bunch. You have lots of capacity if you are only looking at a 2000 lb TC.
2004 Dodge Laramie 3500 Dually, CTD 305/555, Quad Cab, 4x4, NV5600, Torklift SuperHitch/SuperTruss
2008 Eagle Cap 995, 310W Solar
woodhog
NS
Posted: 02/23/12 10:20am Link  |  Print  |  Notify Moderator
I would say 3500 to 4000 pounds payload easily, buy something to take the squat out depending on the load, keep the overloads engaged to prevent rolling side to side, (Torklift stable loads etc) you will be good to go..
anti roll, anti squat
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow, 3 Batteries 200 Watts Solar,
12 Volt DC Fridge.
fuelhauler
Southern Oregon
Posted: 02/23/12 12:01pm Link  |  Print  |  Notify Moderator
My 2005 with our 10.6 Bigfoot scaled at 12,350 lbs loaded for the weekend with full water on board. Thats 150lbs over my GVWR She just engages the overloads. The tc scaled at 4K lbs. I do have air bags but don't put much air in them. I use them more for leveling when camped. I also have the stabil loads which alow me to run 20 lbs of air in the bags & still keep the overloads engaged. Hope this helps.
2005 Dodge q/c 4x4 dually six speed pac brake
2014 Arctic Fox 990
2014 16' smokercraft
KKELLER14K
BEAVERTON OREGON
Posted: 02/23/12 02:54pm Link  |  Print  |  Notify Moderator
Have an 02 Dodge 6 speed with an AF 1150 around 5k loaded. Drives just fine...have air bags and an on-board air controller. This would be the top end. If your in the 2 to 4k range you wouldn't have to do a thing.
bjbear
Cold Lake, AB, Can
Posted: 02/23/12 06:16pm Link  |  Print  |  Notify Moderator
I have a 2003 DRW Dodge with a 10 1/2 foot camper that weighs in at ~3300 lbs dry weight. When fully loaded, I am just a bit over GVWR but OK on Axles and tire. Have air bags, but the truck does alright without them as well. I would say I was at max load.
You can check out my weights at:
My Camper
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toad - 2014 GMC Terrain
My Website
mkirsch
Rochester, NY
Posted: 02/24/12 11:19am Link  |  Print  |  Notify Moderator
Yeah, 2000lbs won't even bring the truck down to level.
There are two main reasons I'm running such a light camper on my DRW:
1. Towing a heavy trailer. I've got a 7-ton trailer that can have as much as 2000lbs on the tongue.
2. Overhead clearance in my pole barn. The doors are only 10' high, and a hardside camper with AC on the roof won't clear.
Putting 10-ply tires on half ton trucks since 2017.
