RV.Net Open Roads Forum: 19K lb 5th wheel hitch for B&W turnover?
Search only in Tow Vehicles
 > 19K lb 5th wheel hitch for B&W turnover?
Dave Wilburn
Ogden UT
Posted: 02/22/12 08:45pm Link  |  Print  |  Notify Moderator
My truck has a B&W turnover gooseneck hitch. I had always planned on buying the Companion 5er hitch when I bought a new trailer. Problem is the B&W Companion is only rated at 18K, and the 5er we are looking at has GVWR of 19K. Is there another manufacturer that makes a 5er hitch rated for that big of a trailer? Am I going to have to remove the B&W to put in rails and a 5er hitch?
04.5 Ram 3500, '12 Voltage 3905 Epic, 69 baja bug
MadMav
Colorado Springs, CO
Posted: 02/22/12 09:14pm Link  |  Print  |  Notify Moderator
Normaly you would have to put in rails to get a hitch with greater than 18k rating.
Or get a gooseneck adaptor for the fiver. They are rated at 30k. But good luck getting the manufacture to approve that!
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
TAS
Baton Rouge, La
Posted: 02/23/12 05:41am Link  |  Print  |  Notify Moderator
I've got the Colibert Free Ride hitch for my B&W set-up. Mine is an 18K but they might make higher rated hitches. Search Colibert on the web and see. Good luck
Todd
12 F-350 4x4 CC DRW
07 Dodge 2500, 4x4, CTD, 6spd (sold)
94 Harley FLSTC
98 TJ w/ a few mods
08 Fuzion 302
01 Rockwood 8292s (gone to a new home)
84 Jayco pop up (Sold but not frogotten)
MadMav
Posted: 02/23/12 08:34am Link  |  Print  |  Notify Moderator
The Colibert's only go up to 18k, and have a very light 3500lb vert load limit.
Mav
Dave Wilburn
Ogden UT
Posted: 02/23/12 08:42am Link  |  Print  |  Notify Moderator
Thanks, thats what I figured. I just hope I can figure out how to mount rails without having to remove the B&W.
Any recomendations on which hitch to get? The dealer stocks a 20K pullrite and wants $1000 for it. Installation is an extra $500. Seems steep to me.
oliver 550
Alabama
Posted: 02/23/12 12:16pm Link  |  Print  |  Notify Moderator
Here is what I bought for that exact situation which is rated for 20k lbs. You put this in your B&W hitch and I used my 20K hitch I already had.
http://www.etrailer.com/Accessories-and-Parts/Curt/16310.html
MadMav
Posted: 02/23/12 01:08pm Link  |  Print  |  Notify Moderator
That's the ticket right there.
Then just buy a 20 rated hitch and bingo!
Mav
Dave Wilburn
Ogden UT
Posted: 02/23/12 05:00pm Link  |  Print  |  Notify Moderator
That is EXACTLY what I need! Thank you!
Do you drill holes in the bed and bolt the 4 corners down too? Got any pics of it installed?
Thanks again!
DodgeVoltage
Nanjemoy, MD
Posted: 02/23/12 05:15pm Link  |  Print  |  Notify Moderator
Looks completely removable and not permanent just like the companion. I don't believe you have to bolt anything as it says no drilling required. Probably just has a wider stance than the companion to spread the extra force over a larger area.
I will keep using my Companion. Don't think I will ever load my TH up to the 19,000 lb max.
2010 Dodge 3500 Mega Cab Cummins Diesel DRW
2009 GMC 2500HD D/A Crew Cab
2012 Dutchmen 3795 Voltage Epic Package
2012 Smart Passion for Two
2003 Suzuki Intruder 1500LC Cruiser
AD USAF 1996-2011 1700+ hrs E-3B/C AWACS
NYANG 2011-Present
K-State Wildcats!
vietvet66-67
southeast penna.
Posted: 02/23/12 05:45pm Link  |  Print  |  Notify Moderator
Then get the Curt Q20 - 20,0000# hitch. They make a great hitch and all their products are good. I'm using a Q20 in my truck.
By the way, Amazon has the Q20 for around $500.00 if your interested.
2006 Chevy 3500 DRW LBZ/ALLY LT2 The "DREAM CATCHER"
1999 Newmar American Star Newmar Kountry Klub #19708
Curt Q20 P-2 Controller Vietnam Veteran 1966-1967
LIFE MEMBER OF THE VFW PROUD MEMBER 335 "DUALLY CLUB"
"GOD, GUTS, AND GUNS KEEP AMERICA FREE"
