RV.Net Open Roads Forum: Class A Motorhomes: Changing 30amp to 50amp
 > Changing 30amp to 50amp
Cajunco
colorado
Posted: 02/22/12 09:26pm Link  |  Print  |  Notify Moderator
I have 30amp now and want to add a 2nd AC so i was told i would need 50amp to run both Ac's at the same time..
I know i cant do this myself so i will need a professional but wanted to know if this is alot of trouble and costly to do ?
I have a 1988 Allegro 33ft
Thanks for any help ! !
1988 33ft Allegro Tiffin
Ka Ron
Kelowna
Posted: 02/22/12 09:27pm Link  |  Print  |  Notify Moderator
We have a Class A with 30 amp service to the coach. We use a 50 to 30 adapter and run both A/C's with no problem.
Join Us For A Trip Down The RV Highway
Cajunco
colorado
Posted: 02/22/12 09:31pm Link  |  Print  |  Notify Moderator
Really Ron? it doesnt cut off the breaker ?
Ka Ron
Kelowna
Posted: 02/22/12 09:40pm Link  |  Print  |  Notify Moderator
No it does not.
2 A/C's will run on 30 amp. The problem comes in when they first start up.
When you are plugged into 50 amp your coach will only draw 30 as that is all it can draw.
When the A/C's are both running they are not drawing 30 Amps
Executive
Posted: 02/22/12 09:43pm Link  |  Print  |  Notify Moderator
Ron may be able to run his A/Cs off a 50amp breaker with a 30amp adapter but that doesn't mean he's using 50amps...he still ONLY has 30amp service. He could skip the adapter and achieve the same results. Part of your answer will depend on the size of the A/Cs. If it's really hot, I can only run two of my three A/Cs even with 50amp service. Each one is 15,000btu. In answer to your question, yes, it's possible to convert your coach from 30amp to 50amp but it will be expensive....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
Cajunco
colorado
Posted: 02/22/12 09:44pm Link  |  Print  |  Notify Moderator
So i should be fine running 2 ac's 1 tv and the Refrigerator on 30amps then ?
Cajunco
colorado
Posted: 02/22/12 09:48pm Link  |  Print  |  Notify Moderator
the 2nd ac i want to install will be a 13,000btu but not sure of the one i have up there now?
Ka Ron
Kelowna
Posted: 02/22/12 09:51pm Link  |  Print  |  Notify Moderator
I am, and yes we only draw 30Amp even though we use a 50 AMP adapter, but some park power is not a true 30 Amp and so when you use the 50 you get a true 30 AMP
Steelsmith
Nampa, Idaho
You won't know for sure if you can operate two A/C's until you determine what else is running/sharing power at the same time.
An affordable option is to simply run the second A/C on an independant 20amp extension cord, most RV power posts have a standard 20amp outlet right next to the 30amp outlet. This would give you an extra 20amp circuit, which extends your power available to 50amps.
Cajunco
colorado
Posted: 02/22/12 10:02pm Link  |  Print  |  Notify Moderator
THANKS guys for the INFO !
helped me out alot
Joey
