nagel
Missouri
1996 Coachmen E350
Wanting to replace the Steering Stabilizer with a Bilstein. Anybody know the part number?
Snagel
Steven R. Nagel
j-d
Sunny Florida USA
I'd say call them. They aren't on the site and when I tried another site all I got was the F-53 Class A chassis.
Replaced ours with a Monroe and it seemed to help.
Be sure any damper you get has a boot to protect the rod, or a boot is available for it. It was available for Monroe, even a choice of colors. Damper itself is black.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
nagel
Missouri
Thanks, I'll check with some of the local truck shops and see if they can get me a good price on the Safe-T-Plus or maybe a good Bilstein or Monroe replacement.
Snagel
j-d
Sunny Florida USA
One of our guys here found the S-T-Plus could be bought for much less than advertised price through a truck shop.
nagel
Missouri
Love to do the Safe-T-Plus, but not in the budget right now.
gotsmart
Aberdeen, WA
I had mine replaced last year with a Safe-T-Plus.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
j-d
Sunny Florida USA
Monroe replacement is under $30 at places like Amazon, closer to $20 at RockAuto. Advance had a special and I paid around $30 delivered to the house. Some sellers show "Lifetime Warranty" and others don't. Since Advance does, and there's a store around the corner, I went that way.
The RoadMaster unit looks like the same concept as Safe-T-Plus except the coil "centering" spring is external where you can see it. S-T-P has it inside the tubes. Looked at the RoadMaster install instructions and saw what I always expected. You must be sure the vehicle steering is centered or the stablilizer will introduce a pull to one side or the other. Easy to correct per instructions.
RoadMaster limits their retail outlets much more than Hellwig does for their products. S-T-P uses more outlets too, so chances are you can get that unit at a lower price than RM's stabilizer.
I prefer S-T-P and RM over Safety-Steer (the one with brackets, springs and bellcranks out at the wheels) because it lacks a hydraulic damper. The OEM "stablilzer" I call a "Damper" because it has no centering springs. So:
OEM, Monroe = Damper
Safety-Steer = Centering
S-T-P, RM = Stabilizer (Damper AND Centering)
My ratings, your opinions may vary.
nagel
Missouri
Still got the cheap-o original and something I've been wanting to do. Did also have the rotors turned when I found a brake caliper frozen and causing a really bad shake issue.
1rickw
redwood City, CA USA
I just had a Monroe installed. I had asked my mechanic to try for a Bilstein, but he couldn't get one so put in the Monroe. It has to be better than what I had. Also had my brake rotors turned because of a shimmy when braking going downhill. They were warped.
2004 Jamboree 26Q + great wife to travel with
Kamphiker
South Florida (this 'aint paradise anymore)
I upgraded my factory stock Ford Steering dampener to a Roadmaster
The factory Dampeners are cheap and designed for 3/4 - 1 ton vans and not designed for our chassis.
I only have 500 - 600 miles since the upgrade but I can so far feel a much better "on Center" experience. So far only have been driving in calm weather and typical Southern Fla. Roads so I cant really say Awesome or just a decent upgrade at this time.
install was easy.
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
